cgal-discuss - Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails.
  • To:
  • Subject: Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails.
  • Date: Tue, 14 May 2013 08:50:52 +0200
On 05/13/2013 08:12 PM, placebo wrote:
Philipp,
Thank you for the response.
Are you saying that you can produce the correct results on a 64-bit system
using the Simple_cartesian kernel? Because I have another system (64-bit
linux) with 64-bit boost, CGAL, etc. and was not able to obtain the correct
results using the Simple_cartesian kernel.
Using the "Exact_predicates_exact_constructions_kernel" does fix the
problem.
Exact_predicates_inexact_constructions_kernel is enough for getting the number of intersections.
Sebastien.
Willie B. Maddox Ph.D.
Physicist / Senior Systems Modeler
Science Applications International Corporation
Huntsville, AL USA
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/triangle-query-to-AABB-triangle-tree-returns-incorrect-intersection-objects-tp4657400p4657416.html
