- To:
- Subject: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails.
- Date: Tue, 14 May 2013 07:50:45 -0700 (PDT)
hello
Sebastien is right ~ I use this AABB Tree a few weeks ago ~~And if you
want to compute the intersected points~ You can do "intersection object is a
segment ,point_3 a = seg.vertex(0)or (1)"
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/triangle-query-to-AABB-triangle-tree-returns-incorrect-intersection-objects-tp4657400p4657424.html
- [cgal-discuss] triangle_query to AABB_triangle_tree fails., placebo, 05/09/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree returns incorrect intersection objects, placebo, 05/09/2013
- Re: [cgal-discuss] triangle_query to AABB_triangle_tree fails., Philipp Moeller, 05/10/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., placebo, 05/13/2013
- Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., Sebastien Loriot (GeometryFactory), 05/14/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., placebo, 05/14/2013
- Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., Sebastien Loriot (GeometryFactory), 05/15/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., ChaoM, 05/14/2013
