- To:
- Subject: Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails.
- Date: Wed, 15 May 2013 07:21:13 +0200
On 05/14/2013 06:27 PM, placebo wrote:
Sebastien,Sorry I meant constructing the intersection.
Do I need to construct the point?
In the example above, the points are the first thing I "construct". The
triangles are constructed from those points and the tree is constructed from
the triangles. My query triangle is also constructed from the points. So,
should not the points already be constructed? I do not see why to
reconstruct them.
Thanks.
If you don't, then you can call all_intersected_primitives and use
orientation tests with triangle points to see in which case you are.
This would require a kernel with only exact predicates.
Sebastien.
Willie B. Maddox Ph.D.
Physicist / Senior Systems Modeler
Science Applications International Corporation
Huntsville, AL USA
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/triangle-query-to-AABB-triangle-tree-returns-incorrect-intersection-objects-tp4657400p4657430.html
- [cgal-discuss] triangle_query to AABB_triangle_tree fails., placebo, 05/09/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree returns incorrect intersection objects, placebo, 05/09/2013
- Re: [cgal-discuss] triangle_query to AABB_triangle_tree fails., Philipp Moeller, 05/10/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., placebo, 05/13/2013
- Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., Sebastien Loriot (GeometryFactory), 05/14/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., placebo, 05/14/2013
- Re: [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., Sebastien Loriot (GeometryFactory), 05/15/2013
- [cgal-discuss] Re: triangle_query to AABB_triangle_tree fails., ChaoM, 05/14/2013
