cgal-discuss - Re: [cgal-discuss] Re: update of power diagram vertices
  • To:
  • Subject: Re: [cgal-discuss] Re: update of power diagram vertices
  • Date: Mon, 20 May 2013 16:00:30 +0200
On 05/20/2013 03:55 PM, 杨成林 wrote:
There is a move() function in Triangulation_2, Triangulation_3,
Delaunay_triangulation_2, Delaunay_triangulation_3 and
Regular_triangulation_3. Why is there not such a function in
Regular_triangulation_2?
There is, it is inherited. Just call it with your regular triangulation and it will work.
Sebastien.
2013/5/20 Sebastien Loriot (GeometryFactory)
<mailto:>>
you need to explicitly call move (documented in the base class
Triangulation_2 [1]) each time you want to update a weight.
Note that a Vertex_handle is not valid when its vertex becomes hidden.
[1]
http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Triangulation_2_ref/Class___Triangulation_2.htm
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.htm>
Sebastien.
It should not be hard to write a member method function update_weight.
On 05/20/2013 08:51 AM, liudaisuda wrote:
Anyone? Please. The regular triangulation in my algorithm needs
to be updated
thousands of times. I got to find an efficient way. Indeed, my
approach
right now is for each update of a single vertex information , I
cleared all
vertices of the regular triangulation and reload all vertex
information
again. While this worked, but it was too time-consuming. Please
help if you
can. Thanks a lot.
View this message in context:
http://cgal-discuss.949826.n4.__nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html
<http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657501.html>
https://sympa.inria.fr/sympa/__info/cgal-discuss
<https://sympa.inria.fr/sympa/info/cgal-discuss>
杨成林
Yang Chenglin
