- To:
- Subject: Re: [cgal-discuss] Re: update of power diagram vertices
- Date: Tue, 21 May 2013 17:20:32 +0800
move() function accepts both types, Point_2 and Weighted_point_2. But
if Weighted_point_2
is used, rt.is_valid() may throw Assertion_exception because the
triangulation cannot pass power_test().
2013/5/21, Sebastien Loriot (GeometryFactory)
> After digging a bit, I found out that the move function is not
> documented on purpose for regular triangulations as it does not work as
> soon as a vertex gets hidden.
> Sebastien.
> On 05/20/2013 05:34 PM, Sebastien Loriot (GeometryFactory) wrote:
>> On 05/20/2013 05:04 PM, 杨成林 wrote:
>>> I may be wrong. I have not noticed Weighted_point_mapper_2. Is this
>>> another self-reference in CGAL? I don't understand the usage of Self and
>>> Base.
>> In Regular_triangulation_2.h, it is used to define the Traits of the
>> base class Triangulation_2< Weighted_point_mapper_2<Gt> >.
>> Sebastien.
>>> The doc is lying then.
>>> Anyway, it is working thanks to Weighted_point_mapper_2.
>>> Sebastien.
>>> 2013/5/20 Sebastien Loriot (GeometryFactory)
>>> <mailto:>
>>> <mailto:
>>> <mailto:>>>
>>> On 05/20/2013 04:15 PM, 杨成林 wrote:
>>> > Why does only Regular_triangulation_2 inherit the function, but
>>> others
>>> > redefine it?
>>> > In Regular_triangulation_3, the type of the second parameter of
>>> move()
>>> > function is Gt::Weighted_point_3. But the type in the function
>>> inherited
>>> > from Triangulation_2 is Gt::Point_2. They do not match.
>>> The Point type is Traits::Point_2 which is the weighted
>>> point if you
>>> use the regular traits.
>>> Sebastien.
>>> <mailto:>
>>> <mailto:
>>> <mailto:>>
>>> > <mailto:
>>> > <mailto:>
>>> <mailto:
>>> <mailto:>>>__>
>>> > On 05/20/2013 03:55 PM, 杨成林 wrote:
>>> > There is a move() function in Triangulation_2,
>>> Triangulation_3,
>>> > Delaunay_triangulation_2, Delaunay_triangulation_3 and
>>> > Regular_triangulation_3. Why is there not such a
>>> function in
>>> > Regular_triangulation_2?
>>> > There is, it is inherited. Just call it with your regular
>>> > triangulation and it will work.
>>> > Sebastien.
>>> > <mailto:>
>>> <mailto:
>>> <mailto:>>
>>> <mailto:
>>> <mailto:>
>>> <mailto:
>>> <mailto:>>>
>>> > <mailto:
>>> > <mailto:>
>>> <mailto:
>>> <mailto:>>
>>> <mailto:
>>> <mailto:>
>>> <mailto:
>>> <mailto:>>>__>>
>>> > you need to explicitly call move (documented in the base
>>> class
>>> > Triangulation_2 [1]) each time you want to update a
>>> weight.
>>> > Note that a Vertex_handle is not valid when its vertex
>>> becomes
>>> > hidden.
>>> > [1]
>>> http://www.cgal.org/Manual/______latest/doc_html/cgal_manual/______Triangulation_2_ref/Class_______Triangulation_2.htm
>>> <http://www.cgal.org/Manual/____latest/doc_html/cgal_manual/____Triangulation_2_ref/Class_____Triangulation_2.htm>
>>> <http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Triangulation_2_ref/Class___Triangulation_2.htm>>
>>> <http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.htm>>>
>>> > Sebastien.
>>> > It should not be hard to write a member method function
>>> > update_weight.
>>> > On 05/20/2013 08:51 AM, liudaisuda wrote:
>>> > Anyone? Please. The regular triangulation in my algorithm
>>> needs
>>> > to be updated
>>> > thousands of times. I got to find an efficient way.
>>> Indeed, my
>>> > approach
>>> > right now is for each update of a single vertex
>>> information , I
>>> > cleared all
>>> > vertices of the regular triangulation and reload all
>>> vertex
>>> > information
>>> > again. While this worked, but it was too time-consuming.
>>> Please
>>> > help if you
>>> > can. Thanks a lot.
>>> > View this message in context:
>>> http://cgal-discuss.949826.n4.______nabble.com/update-of-__power-____diagram-vertices-______tp4657493p4657501.html
>>> <http://nabble.com/update-of-power-____diagram-vertices-____tp4657493p4657501.html>
>>> <http://nabble.com/update-of-__power-____diagram-vertices-______tp4657493p4657501.html
>>> <http://nabble.com/update-of-power-____diagram-vertices-____tp4657493p4657501.html>>
>>> <http://nabble.com/update-of-__power-__diagram-vertices-____tp4657493p4657501.html
>>> <http://nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html>>
>>> <http://cgal-discuss.949826.____n4.nabble.com/update-of-power-____diagram-vertices-____tp4657493p4657501.html
>>> <http://n4.nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html>
>>> <http://n4.nabble.com/update-__of-power-__diagram-vertices-____tp4657493p4657501.html
>>> <http://n4.nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html>>
>>> <http://cgal-discuss.949826.__n4.nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html
>>> <http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657501.html>>>
>>> > Sent from the cgal-discuss mailing list archive at
>>> Nabble.com.
>>> > You are currently subscribed to cgal-discuss.
>>> > To unsubscribe or access the archives, go to
>>> > https://sympa.inria.fr/sympa/______info/cgal-discuss
>>> <https://sympa.inria.fr/sympa/____info/cgal-discuss>
>>> <https://sympa.inria.fr/sympa/__info/cgal-discuss>>
>>> <https://sympa.inria.fr/sympa/info/cgal-discuss>>>
>>> > 杨成林
>>> > Yang Chenglin
>>> > 杨成林
>>> > Yang Chenglin
>>> 杨成林
>>> Yang Chenglin
>>> 杨成林
>>> Yang Chenglin
杨成林
Yang Chenglin
- Re: [cgal-discuss] Re: update of power diagram vertices, (continued)
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/21/2013
- [cgal-discuss] Re: update of power diagram vertices, liudaisuda, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, Haibo Chen, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Haibo Chen, 05/21/2013
