cgal-discuss - Re: [cgal-discuss] Re: update of power diagram vertices
  • To:
  • Subject: Re: [cgal-discuss] Re: update of power diagram vertices
  • Date: Mon, 20 May 2013 22:37:41 +0800
Line 63-64 in Regular_triangulation_2.h
typedef typename Gt::Point_2                 Bare_point;
typedef typename Gt::Weighted_point_2        Weighted_point;
Gt::Point_2 and Gt::Weighted_point_2 are obviously different.
2013/5/20 Sebastien Loriot (GeometryFactory) <>
On 05/20/2013 04:15 PM, 杨成林 wrote:
> Why does only Regular_triangulation_2 inherit the function, but others
> redefine it?
> In Regular_triangulation_3, the type of the second parameter of move()
> function is Gt::Weighted_point_3. But the type in the function inherited
> from Triangulation_2 is Gt::Point_2. They do not match.
The Point type is  Traits::Point_2 which is the weighted point if you
use the regular traits.
Sebastien.
> <mailto:>>
>     On 05/20/2013 03:55 PM, 杨成林 wrote:
>         There is a move() function in Triangulation_2, Triangulation_3,
>         Delaunay_triangulation_2, Delaunay_triangulation_3 and
>         Regular_triangulation_3. Why is there not such a function in
>         Regular_triangulation_2?
>     There is, it is inherited. Just call it with your regular
>     triangulation and it will work.
>     Sebastien.
>         < <mailto:>
>         <mailto: <mailto:>>>
>         you need to explicitly call move (documented in the base class
>         Triangulation_2 [1]) each time you want to update a weight.
>         Note that a Vertex_handle is not valid when its vertex becomes
>         hidden.
>         [1]
>         http://www.cgal.org/Manual/____latest/doc_html/cgal_manual/____Triangulation_2_ref/Class_____Triangulation_2.htm
>         <http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Triangulation_2_ref/Class___Triangulation_2.htm>
>         <http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.htm>>
>         Sebastien.
>         It should not be hard to write a member method function
>         update_weight.
>         On 05/20/2013 08:51 AM, liudaisuda wrote:
>         Anyone? Please. The regular triangulation in my algorithm needs
>         to be updated
>         thousands of times. I got to find an efficient way. Indeed, my
>         approach
>         right now is for each update of a single vertex information , I
>         cleared all
>         vertices of the regular triangulation and reload all vertex
>         information
>         again. While this worked, but it was too time-consuming. Please
>         help if you
>         can. Thanks a lot.
>         View this message in context:
>         http://cgal-discuss.949826.n4.____nabble.com/update-of-power-____diagram-vertices-____tp4657493p4657501.html
>         <http://nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html>
>         <http://cgal-discuss.949826.__n4.nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html
>         <http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657501.html>>
>         Sent from the cgal-discuss mailing list archive at Nabble.com.
>         You are currently subscribed to cgal-discuss.
>         To unsubscribe or access the archives, go to
>         https://sympa.inria.fr/sympa/____info/cgal-discuss
>         <https://sympa.inria.fr/sympa/__info/cgal-discuss>
>         <https://sympa.inria.fr/sympa/info/cgal-discuss>>
>         杨成林
>         Yang Chenglin
> 杨成林
> Yang Chenglin
杨成林
Yang Chenglin
