- To:
- Subject: Re: [cgal-discuss] Re: update of power diagram vertices
- Date: Tue, 21 May 2013 18:08:38 +0200
Yes it should work.
Sebastien.
On 05/21/2013 06:01 PM, liudaisuda wrote:
Based on my understanding of your information, when in cases where I am
not sure about whether a vertex would be hidden after movement, it is
inappropriate to call move() to update positions of vertices. What do
you think?
On Tue, May 21, 2013 at 3:39 PM, Sebastien Loriot (GeometryFactory) [via
cgal-discuss] <[hidden email]
</user/SendEmail.jtp?type=node&node=4657539&i=0>> wrote:
After digging a bit, I found out that the move function is not
documented on purpose for regular triangulations as it does not work as
soon as a vertex gets hidden.
Sebastien.
On 05/20/2013 05:34 PM, Sebastien Loriot (GeometryFactory) wrote:
> On 05/20/2013 05:04 PM, 杨成林 wrote:
>> I may be wrong. I have not noticed Weighted_point_mapper_2. Is this
>> another self-reference in CGAL? I don't understand the usage of
Self and
>> Base.
> In Regular_triangulation_2.h, it is used to define the Traits of the
> base class Triangulation_2< Weighted_point_mapper_2<Gt> >.
> Sebastien.
>> The doc is lying then.
>> Anyway, it is working thanks to Weighted_point_mapper_2.
>> Sebastien.
>> 2013/5/20 Sebastien Loriot (GeometryFactory)
>> <[hidden email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=0>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=1>>
>> < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=2>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=3>>>>
>> On 05/20/2013 04:15 PM, 杨成林 wrote:
>> > Why does only Regular_triangulation_2 inherit the function, but
>> others
>> > redefine it?
>> > In Regular_triangulation_3, the type of the second parameter of
>> move()
>> > function is Gt::Weighted_point_3. But the type in the function
>> inherited
>> > from Triangulation_2 is Gt::Point_2. They do not match.
>> The Point type is Traits::Point_2 which is the weighted
>> point if you
>> use the regular traits.
>> Sebastien.
>> <[hidden email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=4>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=5>>
>> < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=6>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=7>>>
>> > < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=8>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=9>>
>> < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=10>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=11>>>>__>
>> > On 05/20/2013 03:55 PM, 杨成林 wrote:
>> > There is a move() function in Triangulation_2,
>> Triangulation_3,
>> > Delaunay_triangulation_2, Delaunay_triangulation_3 and
>> > Regular_triangulation_3. Why is there not such a
>> function in
>> > Regular_triangulation_2?
>> > There is, it is inherited. Just call it with your regular
>> > triangulation and it will work.
>> > Sebastien.
>> > <[hidden email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=12>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=13>>
>> < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=14>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=15>>>
>> < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=16>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=17>>
>> < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=18>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=19>>>>
>> > < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=20>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=21>>
>> < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=22>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=23>>>
>> < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=24>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=25>>
>> < email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=26>
< email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=27>>>>__>>
>> > you need to explicitly call move (documented in the base
>> class
>> > Triangulation_2 [1]) each time you want to update a
>> weight.
>> > Note that a Vertex_handle is not valid when its vertex
>> becomes
>> > hidden.
>> > [1]
http://www.cgal.org/Manual/______latest/doc_html/cgal_manual/______Triangulation_2_ref/Class_______Triangulation_2.htm
<http://www.cgal.org/Manual/____latest/doc_html/cgal_manual/____Triangulation_2_ref/Class_____Triangulation_2.htm>
<http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Triangulation_2_ref/Class___Triangulation_2.htm>>
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.htm>>>
>> > Sebastien.
>> > It should not be hard to write a member method function
>> > update_weight.
>> > On 05/20/2013 08:51 AM, liudaisuda wrote:
>> > Anyone? Please. The regular triangulation in my algorithm
>> needs
>> > to be updated
>> > thousands of times. I got to find an efficient way.
>> Indeed, my
>> > approach
>> > right now is for each update of a single vertex
>> information , I
>> > cleared all
>> > vertices of the regular triangulation and reload all
>> vertex
>> > information
>> > again. While this worked, but it was too time-consuming.
>> Please
>> > help if you
>> > can. Thanks a lot.
>> > View this message in context:
http://cgal-discuss.949826.n4.______nabble.com/update-of-__power-____diagram-vertices-______tp4657493p4657501.html
<http://nabble.com/update-of-power-____diagram-vertices-____tp4657493p4657501.html>
<http://nabble.com/update-of-__power-____diagram-vertices-______tp4657493p4657501.html
<http://nabble.com/update-of-power-____diagram-vertices-____tp4657493p4657501.html>>
<http://nabble.com/update-of-__power-__diagram-vertices-____tp4657493p4657501.html
<http://nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html>>
<http://cgal-discuss.949826.____n4.nabble.com/update-of-power-____diagram-vertices-____tp4657493p4657501.html
<http://n4.nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html>
<http://n4.nabble.com/update-__of-power-__diagram-vertices-____tp4657493p4657501.html
<http://n4.nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html>>
<http://cgal-discuss.949826.__n4.nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html
<http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657501.html>>>
>> > Sent from the cgal-discuss mailing list archive at
>> Nabble.com.
>> > You are currently subscribed to cgal-discuss.
>> > To unsubscribe or access the archives, go to
>> > https://sympa.inria.fr/sympa/______info/cgal-discuss
>> <https://sympa.inria.fr/sympa/____info/cgal-discuss>
>> <https://sympa.inria.fr/sympa/__info/cgal-discuss>>
>> <https://sympa.inria.fr/sympa/info/cgal-discuss>>>
>> > 杨成林
>> > Yang Chenglin
>> > 杨成林
>> > Yang Chenglin
>> 杨成林
>> Yang Chenglin
>> 杨成林
>> Yang Chenglin
If you reply to this email, your message will be added to the
discussion below:
http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657523.html
To unsubscribe from update of power diagram vertices, click here.
NAML
<http://cgal-discuss.949826.n4.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: update of power diagram vertices
<http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657539.html>
<http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
- Re: [cgal-discuss] Re: update of power diagram vertices, (continued)
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/21/2013
- [cgal-discuss] Re: update of power diagram vertices, liudaisuda, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, Haibo Chen, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Haibo Chen, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/23/2013
