cgal-discuss - Re: [cgal-discuss] Re: update of power diagram vertices
  • To:
  • Subject: Re: [cgal-discuss] Re: update of power diagram vertices
  • Date: Mon, 20 May 2013 16:45:55 +0200
On 05/20/2013 04:37 PM, 杨成林 wrote:
Line 63-64 in Regular_triangulation_2.h
typedef typename Gt::Point_2 Bare_point;
typedef typename Gt::Weighted_point_2 Weighted_point;
Gt::Point_2 and Gt::Weighted_point_2 are obviously different.
The doc is lying then.
Anyway, it is working thanks to Weighted_point_mapper_2.
Sebastien.
2013/5/20 Sebastien Loriot (GeometryFactory)
<mailto:>>
On 05/20/2013 04:15 PM, 杨成林 wrote:
> Why does only Regular_triangulation_2 inherit the function, but
others
> redefine it?
> In Regular_triangulation_3, the type of the second parameter of
move()
> function is Gt::Weighted_point_3. But the type in the function
inherited
> from Triangulation_2 is Gt::Point_2. They do not match.
The Point type is Traits::Point_2 which is the weighted point if you
use the regular traits.
Sebastien.
<mailto:>
<mailto:
<mailto:>>>
> On 05/20/2013 03:55 PM, 杨成林 wrote:
> There is a move() function in Triangulation_2,
Triangulation_3,
> Delaunay_triangulation_2, Delaunay_triangulation_3 and
> Regular_triangulation_3. Why is there not such a function in
> Regular_triangulation_2?
> There is, it is inherited. Just call it with your regular
> triangulation and it will work.
> Sebastien.
<mailto:>
<mailto:
<mailto:>>
<mailto:
<mailto:>
<mailto:
<mailto:>>>>
> you need to explicitly call move (documented in the base
class
> Triangulation_2 [1]) each time you want to update a weight.
> Note that a Vertex_handle is not valid when its vertex
becomes
> hidden.
> [1]
http://www.cgal.org/Manual/____latest/doc_html/cgal_manual/____Triangulation_2_ref/Class_____Triangulation_2.htm
<http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Triangulation_2_ref/Class___Triangulation_2.htm>
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.htm>>
> Sebastien.
> It should not be hard to write a member method function
> update_weight.
> On 05/20/2013 08:51 AM, liudaisuda wrote:
> Anyone? Please. The regular triangulation in my algorithm
needs
> to be updated
> thousands of times. I got to find an efficient way.
Indeed, my
> approach
> right now is for each update of a single vertex
information , I
> cleared all
> vertices of the regular triangulation and reload all vertex
> information
> again. While this worked, but it was too time-consuming.
Please
> help if you
> can. Thanks a lot.
> View this message in context:
http://cgal-discuss.949826.n4.____nabble.com/update-of-power-____diagram-vertices-____tp4657493p4657501.html
<http://nabble.com/update-of-power-____diagram-vertices-____tp4657493p4657501.html>
<http://nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html>
<http://cgal-discuss.949826.__n4.nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html
<http://n4.nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html>
<http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657501.html>>
> Sent from the cgal-discuss mailing list archive at
Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/____info/cgal-discuss
> <https://sympa.inria.fr/sympa/__info/cgal-discuss>
> <https://sympa.inria.fr/sympa/info/cgal-discuss>>
> 杨成林
> Yang Chenglin
> 杨成林
> Yang Chenglin
杨成林
Yang Chenglin
