- To:
- Subject: Re: [cgal-discuss] Re: update of power diagram vertices
- Date: Mon, 20 May 2013 22:15:12 +0800
Why does only Regular_triangulation_2 inherit the function, but others redefine it?
In Regular_triangulation_3, the type of the second parameter of move() function is Gt::Weighted_point_3. But the type in the function inherited from Triangulation_2 is Gt::Point_2. They do not match.
2013/5/20 Sebastien Loriot (GeometryFactory) <>
On 05/20/2013 03:55 PM, 杨成林 wrote:There is, it is inherited. Just call it with your regular triangulation and it will work.
There is a move() function in Triangulation_2, Triangulation_3,
Delaunay_triangulation_2, Delaunay_triangulation_3 and
Regular_triangulation_3. Why is there not such a function in
Regular_triangulation_2?
Sebastien.
<mailto:>>http://www.cgal.org/Manual/__latest/doc_html/cgal_manual/__Triangulation_2_ref/Class___Triangulation_2.htm
you need to explicitly call move (documented in the base class
Triangulation_2 [1]) each time you want to update a weight.
Note that a Vertex_handle is not valid when its vertex becomes hidden.
[1]http://cgal-discuss.949826.n4.__nabble.com/update-of-power-__diagram-vertices-__tp4657493p4657501.html
<http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Triangulation_2_ref/Class_Triangulation_2.htm>
Sebastien.
It should not be hard to write a member method function update_weight.
On 05/20/2013 08:51 AM, liudaisuda wrote:
Anyone? Please. The regular triangulation in my algorithm needs
to be updated
thousands of times. I got to find an efficient way. Indeed, my
approach
right now is for each update of a single vertex information , I
cleared all
vertices of the regular triangulation and reload all vertex
information
again. While this worked, but it was too time-consuming. Please
help if you
can. Thanks a lot.
View this message in context:https://sympa.inria.fr/sympa/__info/cgal-discuss
<http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657501.html>
杨成林
Yang Chenglin
- [cgal-discuss] update of power diagram vertices, liudaisuda, 05/19/2013
- [cgal-discuss] Re: update of power diagram vertices, liudaisuda, 05/19/2013
- Re: [cgal-discuss] update of power diagram vertices, 杨成林, 05/19/2013
- [cgal-discuss] Re: update of power diagram vertices, liudaisuda, 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/21/2013
- [cgal-discuss] Re: update of power diagram vertices, liudaisuda, 05/21/2013
