cgal-discuss - [cgal-discuss] Re: update of power diagram vertices
  • To:
  • Subject: [cgal-discuss] Re: update of power diagram vertices
  • Date: Tue, 21 May 2013 09:11:42 -0700 (PDT)
Referring to CGAL manual, I found the method you mentioned as described in
the doc, t.move ( Vertex_handle v, Point p). It seemed like it's called to
update positions. Can you think of something similar to update weights,
which is the major task in my algorithm? Thanks again for your help
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/update-of-power-diagram-vertices-tp4657493p4657542.html
