- To: "" <>
- Subject: Re: [cgal-discuss] update of power diagram vertices
- Date: Wed, 22 May 2013 13:32:14 +0800
well,the doc of regular triangulation 2 defines Trait:point2 as point2, and the weighted point mapper2 maps Geotraits: weighted point2 to point2. Hence, I believe wloroit that it will work. I havent tried it, but i definitely will. I'll let u know then. It's tempting to try.
在 2013年5月22日星期三,杨成林 写道:
I don't think the inherited move function can work well in Regular_triangulation_2 while all the other triangulations implement their own move functions. Is this a bug?
在 2013-5-22 上午12:09,"Sebastien Loriot (GeometryFactory)" <>写道:
Yes it should work.
Sebastien.
On 05/21/2013 06:01 PM, liudaisuda wrote:
Based on my understanding of your information, when in cases where I am
not sure about whether a vertex would be hidden after movement, it is
inappropriate to call move() to update positions of vertices. What do
you think?
On Tue, May 21, 2013 at 3:39 PM, Sebastien Loriot (GeometryFactory) [via
cgal-discuss] <[hidden email]
</user/SendEmail.jtp?type=node&node=4657539&i=0>> wrote:
After digging a bit, I found out that the move function is not
documented on purpose for regular triangulations as it does not work as
soon as a vertex gets hidden.
Sebastien.
On 05/20/2013 05:34 PM, Sebastien Loriot (GeometryFactory) wrote:
> On 05/20/2013 05:04 PM, 杨成林 wrote:
>> I may be wrong. I have not noticed Weighted_point_mapper_2. Is this
>> another self-reference in CGAL? I don't understand the usage of
Self and
>> Base.
> In Regular_triangulation_2.h, it is used to define the Traits of the
> base class Triangulation_2< Weighted_point_mapper_2<Gt> >.
> Sebastien.
>> The doc is lying then.
>> Anyway, it is working thanks to Weighted_point_mapper_2.
>> Sebastien.
>> 2013/5/20 Sebastien Loriot (GeometryFactory)
>> <[hidden email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=0>
<mailto:[hidden email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=1>>
<http://user/SendEmail.jtp?type=node&node=4657523&i=2>
<http://user/SendEmail.jtp?type=node&node=4657523&i=3>>>>
>> On 05/20/2013 04:15 PM, 杨成林 wrote:
>> > Why does only Regular_triangulation_2 inherit the function, but
>> others
>> > redefine it?
>> > In Regular_triangulation_3, the type of the second parameter of
>> move()
>> > function is Gt::Weighted_point_3. But the type in the function
>> inherited
>> > from Triangulation_2 is Gt::Point_2. They do not match.
>> The Point type is Traits::Point_2 which is the weighted
>> point if you
>> use the regular traits.
>> Sebastien.
>> <[hidden email]
<http://user/SendEmail.jtp?type=node&node=4657523&i=4>
<http://user/SendEmail.jtp?type=node&node=4657523&i=5>>
<http://user/SendEmail.jtp?type=node&node=4657523&i=6>
<http://user/SendEmail.jtp?type=node&node=4657523&i=7>>>
<http://user/SendEmail.jtp?type=node&node=4657523&i=8>
<http://user/SendEmail.jtp?type=node&node=4657523&i=9>>
- Re: [cgal-discuss] Re: update of power diagram vertices, (continued)
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/20/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/21/2013
- [cgal-discuss] Re: update of power diagram vertices, liudaisuda, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, Haibo Chen, 05/22/2013
- Re: [cgal-discuss] update of power diagram vertices, 杨成林, 05/22/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Haibo Chen, 05/21/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Sebastien Loriot (GeometryFactory), 05/23/2013
- Re: [cgal-discuss] Re: update of power diagram vertices, Olivier Devillers, 05/23/2013
