- To:
- Subject: Re: [cgal-discuss] Performance of Triangulation_3
- Date: Wed, 16 Oct 2013 15:43:17 +0200
Hello,
As your points are on an integer grid there will be many
degenerate situations. The situation is even worse
in the scenario with the points being on two parallel
planes.
The benchmarks Oliver refers to are done with random
floating point numbers.
Which release of CGAL do you use? I ask because there
was a recent effort to use a less expensive exact number
types, when tests like orientation predicates fail with
floating point numbers. So in case you use CGAL 4.2,
please retry it with CGAL 4.3beta.
Best regards,
Andreas
On 16/10/2013 15:12, mytien wrote:
This is my benchmark program. I use Qt, but of course you can replace the Qt
functions.
#define _SECURE_SCL 0
#define DCGAL_NDEBUG
#include <QTime>
#include <QElapsedTimer>
#include <CGAL/Delaunay_triangulation_3.h>
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Delaunay_triangulation_3<K> Triangulation;
typedef K::Point_3 CGAL_Point;
int main(int argc, char *argv[])
Triangulation tri;
CGAL_Point p;
float x, y, z;
int numPoints = 0;
QElapsedTimer timer;
int cloudSize = 50000; // adjust point cloud size
qsrand(QTime::currentTime().msec()); //seed for rand()
// create two layers of points
std::vector<CGAL_Point> points(cloudSize);
qDebug("start generating random points");
for(int i = 0; i < cloudSize/2; i++) {
x = rand() % 2000;
y = rand() % 2000;
z = 50;
p = CGAL_Point(x, y, z);
points.push_back(p);
numPoints++;
x = rand() % 2000;
y = rand() % 2000;
z = 150;
numPoints++;
qDebug("start triangulation...\n");
timer.start();
tri.insert(points.begin(), points.end());
qDebug("points: %d, ms: %d\n", numPoints, timer.elapsed());
return 0;
As you notice, I create two layers with random points on them and I found
out that if instead of on the two layers I distribute the points evenly in
space, like this:
for(int i = 0; i < cloudSize; i++) {
x = rand() % 2000;
y = rand() % 2000;
z = 50;
numPoints++;
x = rand() % 2000;
y =
The performance improves.
1000 points: 70 - 130ms
10000 points: 200 - 800ms
20000 poinst: 300 - 1700ms
50000 points: 2500 - 4000ms
Still I am not close to the performance in the manual. Do you think the
randomness of my data is the problem here?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Performance-of-Triangulation-3-tp4658201p4658211.html
Andreas Fabri, PhD
Chief Officer, GeometryFactory
Editor, The CGAL Project
phone: +33.492.954.912 skype: andreas.fabri
- [cgal-discuss] Performance of Triangulation_3, mytien, 10/15/2013
- Re: [cgal-discuss] Performance of Triangulation_3, Monique Teillaud, 10/15/2013
- Re: [cgal-discuss] Performance of Triangulation_3, mytien, 10/16/2013
- Re: [cgal-discuss] Performance of Triangulation_3, Andreas Fabri, 10/16/2013
- Re: [cgal-discuss] Performance of Triangulation_3, mytien, 10/17/2013
- Re: [cgal-discuss] Performance of Triangulation_3, Olivier Devillers, 10/17/2013
- Re: [cgal-discuss] Performance of Triangulation_3, Andreas Fabri, 10/17/2013
