- To:
- Subject: Re: [cgal-discuss] Running CGAL code on cygwin
- Date: Tue, 29 Oct 2013 13:00:15 -0700 (PDT)
Good evening,
Thanks a lot for your answer.
Here is what I find in the CMakeCache.txt:
//CXX compiler.
CMAKE_CXX_COMPILER:FILEPATH=/usr/bin/c++.exe
Thanks,
Shravan1804
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Running-CGAL-code-on-cygwin-tp4658326p4658330.html
- [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/30/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/30/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/31/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/31/2013
