cgal-discuss - Re: [cgal-discuss] Running CGAL code on cygwin
  • To:
  • Subject: Re: [cgal-discuss] Running CGAL code on cygwin
  • Date: Thu, 31 Oct 2013 13:41:27 +0100
Le jeudi 31 octobre 2013 05:13:53 Shravan1804 a écrit :
> One good news.
> I corrected the error from above, apparently some dll files weren't copied
> in the right folders for some unknown reasons. I copied them and the error
> disappeared.
I wonder if `make install` targeting /usr/local can run correctly without
administrator privileges.
> Now I am back with the original error. Here is the output of a compilation
> from a clean build tree of hello-exact:
> cmake . -> hello-exact_cmake_output
> <http://cgal-discuss.949826.n4.nabble.com/file/n4658352/hello-exact_cmake_ou
> tput> make VERBOSE=1 -> hello-exact_make_verbose_output
> <http://cgal-discuss.949826.n4.nabble.com/file/n4658352/hello-exact_make_ver
> bose_output> With this error afterward:
> $ make VERBOSE=1 > hello-exact_make_verbose_output
> CMakeFiles/hello-exact.dir/hello-exact.cpp.o:hello-exact.cpp:(.rdata$.refptr
> ._ZTVN4CORE7SqrtRepE[.refptr._ZTVN4CORE7SqrtRepE]+0x0): undefined reference
> to `vtable for CORE::SqrtRep'
> ._ZTVN4CORE6DivRepE[.refptr._ZTVN4CORE6DivRepE]+0x0): undefined reference to
> `vtable for CORE::DivRep'
> /usr/lib/gcc/x86_64-pc-cygwin/4.8.1/../../../../x86_64-pc-cygwin/bin/ld:
> CMakeFiles/hello-exact.dir/hello-exact.cpp.o: bad reloc address 0x0 in
> section `.rdata$.refptr._ZTVN4CORE6DivRepE[.refptr._ZTVN4CORE6DivRepE]'
> collect2: error: ld returned 1 exit status
> make[2]: *** [hello-exact.exe] Error 1
> make[1]: *** [CMakeFiles/hello-exact.dir/all] Error 2
That target hello-exact must be linked with CGAL_Core. What is your
CMakeLists.txt in the "hello" directory?
Laurent Rineau, PhD
