- To:
- Subject: Re: [cgal-discuss] Running CGAL code on cygwin
- Date: Wed, 30 Oct 2013 15:44:49 +0100
Le mardi 29 octobre 2013 13:28:10 Shravan1804 a écrit :
> Hmm great...
> I decided to uninstall everything following this thread
> <http://cgal-discuss.949826.n4.nabble.com/uninstall-CMAKE-td4342417.html>
> and then reinstall everything thinking that it would maybe solve the
> problem.
> The installation went fine once again following the same steps as above.
> The new problem now is that even hello.cpp doesn't compile anymore :(
> The error is the following:
> $ make
> make[2]: *** No rule to make target `/usr/local/lib/cygCGAL_Core-10.dll',
> needed by `hello.exe'. Stop.
> CMakeFiles/Makefile2:63: recipe for target `CMakeFiles/hello.dir/all' failed
> make[1]: *** [CMakeFiles/hello.dir/all] Error 2
> Makefile:75: recipe for target `all' failed
> make: *** [all] Error 2
Can you restart from a fresh compilation tree of CGAL, and post the output of
`cmake` and `make VERBOSE=1`?
Laurent Rineau, PhD
- [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/30/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/30/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/31/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/31/2013
