- To:
- Subject: Re: [cgal-discuss] Running CGAL code on cygwin
- Date: Thu, 31 Oct 2013 11:48:09 +0100
Le mercredi 30 octobre 2013 12:02:01 Shravan1804 a écrit :
> Good evening,
> I thank you for your answer.
> I uninstalled everything and rerun the installation storing the output:
> cmake . -> cmake_output
> <http://cgal-discuss.949826.n4.nabble.com/file/n4658344/cmake_output>
> make VERBOSE=1 -> make_verbose_output
> <http://cgal-discuss.949826.n4.nabble.com/file/n4658344/make_verbose_output>
> make install -> make_install_output
> <http://cgal-discuss.949826.n4.nabble.com/file/n4658344/make_install_output>
Good, and now, without touching your compilaiton/installation of CGAL, can
you
do the same with the application hello-exact?
Laurent Rineau, PhD
- [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/30/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/30/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/31/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/31/2013
