- To:
- Subject: Re: [cgal-discuss] Running CGAL code on cygwin
- Date: Wed, 30 Oct 2013 12:02:01 -0700 (PDT)
Good evening,
I thank you for your answer.
I uninstalled everything and rerun the installation storing the output:
cmake . -> cmake_output
<http://cgal-discuss.949826.n4.nabble.com/file/n4658344/cmake_output>
make VERBOSE=1 -> make_verbose_output
<http://cgal-discuss.949826.n4.nabble.com/file/n4658344/make_verbose_output>
make install -> make_install_output
<http://cgal-discuss.949826.n4.nabble.com/file/n4658344/make_install_output>
Have a nice evening,
Shravan
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Running-CGAL-code-on-cygwin-tp4658326p4658344.html
- [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/29/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/30/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/30/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Laurent Rineau (CGAL/GeometryFactory), 10/31/2013
- Re: [cgal-discuss] Running CGAL code on cygwin, Shravan1804, 10/31/2013
