cgal-discuss - Re: [cgal-discuss] Running CGAL code on cygwin
  • To:
  • Subject: Re: [cgal-discuss] Running CGAL code on cygwin
  • Date: Thu, 31 Oct 2013 12:40:42 +0100
Le jeudi 31 octobre 2013 04:35:34 Shravan1804 a écrit :
> I copied hello-exact.cpp into a new empty directory then called the
> following commands:
> cgal_create_cmake_script
> cmake . -> hello-exact_cmake_output
> <http://cgal-discuss.949826.n4.nabble.com/file/n4658350/hello-exact_cmake_ou
> tput> make VERBOSE=1 -> hello-exact_make_verbose_output
> <http://cgal-discuss.949826.n4.nabble.com/file/n4658350/hello-exact_make_ver
> bose_output>
> I thank you for your help.
In the build directory of hello-exact, please do:
make clean
and
rm CMakeCache.txt
And reconfigure (with cmake), the directory containing hello-exact.cpp. I
would like to see the output of `cmake` and `make VERBOSE=1` from a clean
compilation tree.
Laurent Rineau, PhD
