[cgal-discuss] Point Set Shape Detection - connected component do not provide expected results
- To:
- Subject: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results
- Date: Fri, 6 Jul 2018 01:16:11 -0700 (MST)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=PermError ; spf=Pass
- Ironport-phdr: 9a23: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
Hello,
I am trying to use the Point Set Shape Detection
<https://doc.cgal.org/latest/Point_set_shape_detection_3/index.html#Chapter_Point_Set_Shape_Detection>
package - in order to detect PLANEs only.
I've defined the value of the parameters as follow:
-probability=0.01
- minPoints=10000
- epsilon=0.01
- clusterEpsilon=0.05
- normalThreshold=0.9
However, it seems that the clusterEpsilon parameter is not correctly taken
into account.
Here is an example of a plane detected by the algorithm.
As one can see, the left part is disconnected from the right part - by a gap
of approx 1.6m.
<http://cgal-discuss.949826.n4.nabble.com/file/t375977/Sans_titre.png>
Is there something I don't get?
Best regards,
Kilian Demeulemeester.
- [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, KDemeul, 07/06/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/06/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/06/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/09/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/09/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/10/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/10/2018
