Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results
- To:
- Subject: Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results
- Date: Mon, 9 Jul 2018 10:52:57 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=None ; spf=None
- Ironport-phdr: 9a23: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
Hello,
I am sorry but I cannot reproduce your bug. Does it happen all the time? RANSAC being based on randomness, it's possible that the result changes from one run to another. Do you have the (x,y,z) coordinates of where this bug happens?
Also, there are no normal vectors in the file you provide. Can you tell me how you estimate these normals? Better, can you share the source code of how you estimate the normals + call RANSAC (maybe just the section of the code if it is part of a larger project)? That way, I am sure I'm doing the same thing.
Best,
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
Le 09/07/2018 à 10:02, Kilian Demeulemeester a écrit :
Hello,
Here is the point cloud in PLY format:
https://drive.google.com/file/d/1cPcxFLQCccmd2X1OWzunc0WtRIiuM9f0/view?usp=sharing
Best,
Bien cordialement.
Directeur R&D
Snapkin | Outil de mesure et de mise en plan 2D/3D pour le bâtiment.
Tél : +33 (0)7 83 49 82 36 | Discutons !
-----Message d'origine-----
De :
De la part de Simon Giraudot
Envoyé : lundi 9 juillet 2018 09:27
À :
Objet : Re: [cgal-discuss] Point Set Shape Detection - connected component do
Hello,
Le 06/07/2018 à 15:33, Kilian Demeulemeester a écrit :
The point cloud is available here:I can't seem to open E57 files, could you convert your point cloud to another
https://drive.google.com/open?id=1r4-9vLq35L6c4SwlGvqppzv6-wrP8nfV (108Mo).
format? (PLY, OFF, LAS, XYZ.)
Thank you,
Simon Giraudot, PhD
R&D Engineer
We are using CGAL 4.10.2.
I've seen that there has been changes relative to that package but... nothing
related to this.
I've checked the release note and didn't see anything related to that bug.
I've also blamed the changes of the method connected_component in
CGAL\Shape_detection_3\Shape_base.h - and did not find any changes lately.
As for now, I think I will try to extend the class
CGAL::Shape_detection_3::Plane<Traits> to create my own version - and
overload the connected_component method to use our own version (using opencv).
Bien cordialement.
Directeur R&D
De :
Envoyé : vendredi 6 juillet 2018 15:04
À :
Hello,
This is indeed unexpected. From what you explain in your email, I don't think
you did anything wrong, so I suspect there is a bug in the package. What
version of CGAL do you use? There has been some changes in the Shape
Detection package lately (but if I remember correctly, nothing that addresses
a bug like this one).
Is there any way you could you share the point cloud so I can try to
reproduce it and find where is the bug?
Best,
Simon Giraudot, PhD
R&D Engineer
Le 06/07/2018 à 10:16, KDemeul a écrit :
Hello,
I am trying to use the Point Set Shape Detection
<https://doc.cgal.org/latest/Point_set_shape_detection_3/index.html#Chapter_Point_Set_Shape_Detection>
package - in order to detect PLANEs only.
I've defined the value of the parameters as follow:
-probability=0.01
- minPoints=10000
- epsilon=0.01
- clusterEpsilon=0.05
- normalThreshold=0.9
However, it seems that the clusterEpsilon parameter is not correctly taken
into account.
Here is an example of a plane detected by the algorithm.
As one can see, the left part is disconnected from the right part - by a gap
of approx 1.6m.
<http://cgal-discuss.949826.n4.nabble.com/file/t375977/Sans_titre.png>
Is there something I don't get?
Best regards,
Kilian Demeulemeester.
- [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, KDemeul, 07/06/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/06/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/06/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/09/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/09/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/10/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/10/2018
