RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results
- To: "" <>
- Subject: RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results
- Date: Mon, 9 Jul 2018 09:44:01 +0000
- Accept-language: fr-FR, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=PermError ; spf=Pass
- Ironport-phdr: 9a23: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
- Spamdiagnosticmetadata: NSPM
- Spamdiagnosticoutput: 1:99
I'll try to create a snippet.
The bugs occur with the parameters I've provided:
- probability=0.01
- minPoints=10000
- epsilon=0.01
- clusterEpsilon=0.05
- normalThreshold=0.9
It looks that the parameter minPoints is the one responsible for this
behavior.
When using the default value, the extracted shapes are correct (but a lot of
them are missing).
Best.
Bien cordialement.
Kilian Demeulemeester
Directeur R&D
Snapkin | Outil de mesure et de mise en plan 2D/3D pour le bâtiment.
Tél : +33 (0)7 83 49 82 36 | Discutons !
-----Message d'origine-----
De :
De la part de Simon Giraudot
Envoyé : lundi 9 juillet 2018 10:53
À :
Objet : Re: [cgal-discuss] Point Set Shape Detection - connected component do
Hello,
I am sorry but I cannot reproduce your bug. Does it happen all the time?
RANSAC being based on randomness, it's possible that the result changes from
one run to another. Do you have the (x,y,z) coordinates of where this bug
happens?
Also, there are no normal vectors in the file you provide. Can you tell me
how you estimate these normals? Better, can you share the source code of how
you estimate the normals + call RANSAC (maybe just the section of the code if
it is part of a larger project)? That way, I am sure I'm doing the same thing.
Best,
Simon Giraudot, PhD
R&D Engineer
GeometryFactory - http://geometryfactory.com/
Le 09/07/2018 à 10:02, Kilian Demeulemeester a écrit :
> Hello,
> Here is the point cloud in PLY format:
> https://drive.google.com/file/d/1cPcxFLQCccmd2X1OWzunc0WtRIiuM9f0/view?usp=sharing
> Best,
> Bien cordialement.
> Directeur R&D
> De :
> Envoyé : lundi 9 juillet 2018 09:27
> À :
> Hello,
> Le 06/07/2018 à 15:33, Kilian Demeulemeester a écrit :
>> The point cloud is available here:
>> https://drive.google.com/open?id=1r4-9vLq35L6c4SwlGvqppzv6-wrP8nfV (108Mo).
> I can't seem to open E57 files, could you convert your point cloud to
> another format? (PLY, OFF, LAS, XYZ.)
> Thank you,
> Simon Giraudot, PhD
> R&D Engineer
>> We are using CGAL 4.10.2.
>> I've seen that there has been changes relative to that package but...
>> nothing related to this.
>> I've checked the release note and didn't see anything related to that bug.
>> I've also blamed the changes of the method connected_component in
>> CGAL\Shape_detection_3\Shape_base.h - and did not find any changes lately.
>> As for now, I think I will try to extend the class
>> CGAL::Shape_detection_3::Plane<Traits> to create my own version - and
>> overload the connected_component method to use our own version (using
>> opencv).
>> Bien cordialement.
>> Directeur R&D
>> De :
>> Envoyé : vendredi 6 juillet 2018 15:04
>> À :
>> Hello,
>> This is indeed unexpected. From what you explain in your email, I don't
>> think you did anything wrong, so I suspect there is a bug in the package.
>> What version of CGAL do you use? There has been some changes in the Shape
>> Detection package lately (but if I remember correctly, nothing that
>> addresses a bug like this one).
>> Is there any way you could you share the point cloud so I can try to
>> reproduce it and find where is the bug?
>> Best,
>> Simon Giraudot, PhD
>> R&D Engineer
>> Le 06/07/2018 à 10:16, KDemeul a écrit :
>>> Hello,
>>> I am trying to use the Point Set Shape Detection
>>> <https://doc.cgal.org/latest/Point_set_shape_detection_3/index.html#Chapter_Point_Set_Shape_Detection>
>>> package - in order to detect PLANEs only.
>>> I've defined the value of the parameters as follow:
>>> -probability=0.01
>>> - minPoints=10000
>>> - epsilon=0.01
>>> However, it seems that the clusterEpsilon parameter is not correctly taken
>>> into account.
>>> Here is an example of a plane detected by the algorithm.
>>> As one can see, the left part is disconnected from the right part - by a
>>> gap
>>> of approx 1.6m.
>>> <http://cgal-discuss.949826.n4.nabble.com/file/t375977/Sans_titre.png>
>>> Is there something I don't get?
>>> Best regards,
>>> Kilian Demeulemeester.
>>> Sent from: http://cgal-discuss.949826.n4.nabble.com/
- [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, KDemeul, 07/06/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/06/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/06/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/09/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/09/2018
- RE: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Kilian Demeulemeester, 07/10/2018
- Re: [cgal-discuss] Point Set Shape Detection - connected component do not provide expected results, Simon Giraudot, 07/10/2018
