Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?
- To:
- Subject: Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?
- Date: Tue, 15 Oct 2019 05:07:32 -0500 (CDT)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23: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
Ok, I will try these.
Thank you.
- [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, tdchen, 10/13/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, Mael, 10/14/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, tdchen, 10/15/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, Mael, 10/15/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, Shrabani Ghosh, 10/15/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, Sebastien Loriot (GeometryFactory), 10/16/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, Shrabani Ghosh, 10/23/2019
