Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?
- To:
- Subject: Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?
- Date: Tue, 15 Oct 2019 05:29:37 -0500 (CDT)
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Fail ; spf=Pass
- Ironport-phdr: 9a23:rXl1IBHxG+WvYwtZLsUMAJ1GYnF86YWxBRYc798ds5kLTJ79rsuwAkXT6L1XgUPTWs2DsrQY0rGQ7PurAzJIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfL1/IA+0oAjfucUan4pvIbstxxXUpXdFZ/5Yzn5yK1KJmBb86Maw/Jp9/ClVpvks6c1OX7jkcqohVbBXAygoPG4z5M3wqBnMVhCP6WcGUmUXiRVHHQ7I5wznU5jrsyv6su192DSGPcDzULs5Vyiu47ttRRT1jioMKjw3/3zNisFogqxVoAyvqR99zI7afY+aO+ZxcKzGcNMGR2dNQtpdWzBdDo+iaYYEEuoPPfxfr4n4v1YOsQaxChWsBOzxzD9Dm3j70bAk3+g8EQzKwQwtEtAQvHnVsNn4L74SUfmvwKbUyjXDaupb1DHg44bGdRAhpOuDXbN2ccfJz0kgDRjKgU6UqYP7JT+ayuMNs22d4uF9Vuyvk3Yqpxx1rzWr3MshhIrEipgWx13F7yl0wYc4KNulQ0Bhe9GkCoFftySCOot2XMwiR2ZotT48yrAJo5K7ejIFx488yB7bdfOLaZSH4hXmVOqJIDd4gmxqeK6nihqv9UWtzvfwW8e33VpQrSdIk8PAu3EM2hDL78iIUPp9/kOv2TaV0ADT7/lJLV0qmabGK5Mt3749m5gNvUnCAiP7g1z2jLaMeko4/eio7vzrYq/6qZ+EK490lgb+P7wylcywG+s4NhECUHWa+eSnyLLj4Fb5QK5Rg/0tkqjZtYjaKt4Bqq64BQ9VyIcj5AylAzeoytRL1UUAeVlKcRbCg4nyMEzVO9j5C+2+ihKiimRF3ffDa6HtCZXAKDCXye24IO8gtBQCkCIq1JZU4JcCWeJJG+76RkKk7I+QNRQ+KQHhm7+7WuU47ZsXXCe0OoHcKLnb4Q2R/6QkJOzePNZE6ga4EOAs4rvVtVF8nFYceaez2p5HOmmhWP9hJhfFOCe+spI6CW4P+zEGYqnqhVmFCGMBYSr0Was27DU2TomhCNWaSw==
Sorry for my poor english.
What I want to ask is that if I can call cost function in placement function
to finally decide the placement.
I mean in the placement function I will try several places and compare their
costs, finally set the placement in the place with the lowest cost.
I am new with STL, and now I just think a policy is a function.
- [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, tdchen, 10/13/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, Mael, 10/14/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, tdchen, 10/15/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, Mael, 10/15/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, Shrabani Ghosh, 10/15/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, Sebastien Loriot (GeometryFactory), 10/16/2019
- Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?, Shrabani Ghosh, 10/23/2019
