cgal-discuss - Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?
  • To:
  • Subject: Re: [cgal-discuss] Is it convenient to change the surface_mesh_simplification a little?
  • Date: Tue, 15 Oct 2019 11:03:23 -0500 (CDT)
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=SoftFail ; spf=Pass
  • Ironport-phdr: 9a23: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
Hi MaelRL,
I had a question similar to this example. As in this example, it defined the
edges as a constrained edge that will not be removed in the simplification
process.
https://doc.cgal.org/latest/Surface_mesh_simplification/Surface_mesh_simplification_2edge_collapse_constrain_sharp_edges_8cpp-example.html
I have to do something opposite. I have to define some edges that has to be
removed in the simplification process. Is there any function that can define
the edges as removed?
Regards
Shrabani Ghosh
