cgal-discuss - Re: [cgal-discuss] Reading a las file.
  • To:
  • Subject: Re: [cgal-discuss] Reading a las file.
  • Date: Thu, 24 Sep 2020 08:13:22 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Hello,
It looks like you did not link with LAS. Can you provide your CMakeLists.txt ? You must have forgotten to link with the target CGAL::LASLIB_support. Have a look here : https://doc.cgal.org/latest/Manual/thirdparty.html#thirdpartyLASlib
Le jeu. 24 sept. 2020 à 05:27, Himanshu Sharma <> a écrit :
Hello,
I am trying to read a .las file into Point_set_3. Below is the code snippent. However this throws following error:
error: no matching function for call to 'make_las_point_reader.
I am not sure what goes wrong here. I understand that the argument to the make_las_point_reader is not of the right type.
std::ifstream ifile (argv[1], std::ios_base::binary);
  CGAL::Point_set_3<Point_3> points;
  if (!CGAL::read_las_points
      (ifile,
       points.index_back_inserter(),
       CGAL::make_las_point_reader(points.point_map())))
      std::cerr << "Error: cannot read file " << argv[1] << std::endl;
      return EXIT_FAILURE;
Regards
Himanshu
