cgal-discuss - Re: [cgal-discuss] Reading a las file.
  • To:
  • Subject: Re: [cgal-discuss] Reading a las file.
  • Date: Thu, 24 Sep 2020 16:21:58 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
Actually it depends on your version of CGAL. <5.1, your code is probably right, if LASLIB_FOUND is TRUE. What is your CMAKE output during configuration ?
NOTICE : the LAS reader found.
or
NOTICE : the LAS reader test requires LASlib and will not be compiled.
Le jeu. 24 sept. 2020 à 16:11, Himanshu Sharma <> a écrit :
I see. I have attached the CMakeLists.txt along.
I tried to follow CMakeLists.txt of read_las_example from Point_set_processing_3, but didnt get it right it seems.
Regards
Himanshu
Sent: Thursday, September 24, 2020 2:13 AM
To: <>
Hello,
It looks like you did not link with LAS. Can you provide your CMakeLists.txt ? You must have forgotten to link with the target CGAL::LASLIB_support. Have a look here : https://doc.cgal.org/latest/Manual/thirdparty.html#thirdpartyLASlib
Le jeu. 24 sept. 2020 à 05:27, Himanshu Sharma <> a écrit :
Hello,
I am trying to read a .las file into Point_set_3. Below is the code snippent. However this throws following error:
error: no matching function for call to 'make_las_point_reader.
I am not sure what goes wrong here. I understand that the argument to the make_las_point_reader is not of the right type.
std::ifstream ifile (argv[1], std::ios_base::binary);
  CGAL::Point_set_3<Point_3> points;
  if (!CGAL::read_las_points
      (ifile,
       points.index_back_inserter(),
       CGAL::make_las_point_reader(points.point_map())))
      std::cerr << "Error: cannot read file " << argv[1] << std::endl;
      return EXIT_FAILURE;
Regards
Himanshu
