cgal-discuss - Re: [cgal-discuss] Reading a las file.
  • To: "" <>
  • Subject: Re: [cgal-discuss] Reading a las file.
  • Date: Thu, 24 Sep 2020 14:11:20 +0000
  • Accept-language: en-US
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=northeastern.edu; dmarc=pass action=none header.from=northeastern.edu; dkim=pass header.d=northeastern.edu; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=8RMQya5Yncn+WoY0kDEBacaAzJ5jwyRUmQYp3PlZ8u4=; b=jj0AJIqcgPSMJZGWh+Ua/odkqzVmR7ozSpioMVqaWmsmoMlukUUUGMm4IEt3V3ehuEXOy3xSaERYAg0FnlIpR+IBo+cW7h5GOkqOppnHEwgFroxDQRm4WlijmvgrT+271S659NE1On5G6jpG+2dKDf2OthxsTWwSCrkiTE5Bi15NcI6pHlhSDKcphJvrj7LQLdMMAIsMIapPYxuFxpP66VFqa51KFyvTovGvXAsmKEheFZ85kYsMz8qYTfelybLK/hb94HxwmSTIaw9Jgfg2w0wLi0bNfzTb3LgfasQRG3fMIn9Eb4YLRDYgtwKIhcfbmAXX4pJrrrd6Pu5Hl/zDtg==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=UCZyYmPxPBOZEFNQSeww0E9sVraGglw9CtODd2vjohE8xaAj168TICn7ci4pIbg1DiSVDsECzzX+sVpltL1WBehy+Gy8JK+/5o1cAFkQJLFstoQmA7pCQrPU3yTWDaoAPn+JmrGxHdOLmDxXcZYQOYQp4vvxKOuNFIY6gbzO81PwHVW5W9hxJTQS96pWKtThgoXjg94SZRRcMp8VfzOcTIsy9kOOFjekrytTvDCg9AmBC7bdHnzoygv+t9uwu4px5wzUGF3WYeHFdwVX0+6tr1/MHyYfy/p8HoQwxl8TNtp5cBl2nxpOYKrkVu/kFdvSGL51Km5/Lh6sCBXvOedo7w==
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
  • Ironport-phdr: 9a23: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
I see. I have attached the CMakeLists.txt along.
I tried to follow CMakeLists.txt of read_las_example from Point_set_processing_3, but didnt get it right it seems.
Regards
Himanshu
Sent: Thursday, September 24, 2020 2:13 AM
To: <>
Hello,
It looks like you did not link with LAS. Can you provide your CMakeLists.txt ? You must have forgotten to link with the target CGAL::LASLIB_support. Have a look here : https://doc.cgal.org/latest/Manual/thirdparty.html#thirdpartyLASlib
Le jeu. 24 sept. 2020 à 05:27, Himanshu Sharma <> a écrit :
Hello,
I am trying to read a .las file into Point_set_3. Below is the code snippent. However this throws following error:
error: no matching function for call to 'make_las_point_reader.
I am not sure what goes wrong here. I understand that the argument to the make_las_point_reader is not of the right type.
std::ifstream ifile (argv[1], std::ios_base::binary);
  CGAL::Point_set_3<Point_3> points;
  if (!CGAL::read_las_points
      (ifile,
       points.index_back_inserter(),
       CGAL::make_las_point_reader(points.point_map())))
      std::cerr << "Error: cannot read file " << argv[1] << std::endl;
      return EXIT_FAILURE;
Regards
Himanshu
# Created by the script cgal_create_CMakeLists
# This is the CMake script for compiling a set of CGAL applications.
cmake_minimum_required(VERSION 3.1...3.15)
project( dsm )
# CGAL and its components
find_package( CGAL QUIET COMPONENTS )
if ( NOT CGAL_FOUND )
message(STATUS "This project requires the CGAL library, and will not be
compiled.")
return()
endif()
# Boost and its components
find_package( Boost REQUIRED )
if ( NOT Boost_FOUND )
message(STATUS "This project requires the Boost library, and will not be
compiled.")
return()
endif()
find_package(LASLIB)
if (LASLIB_FOUND)
message(STATUS "NOTICE : the LAS reader found.")
include(${LASLIB_USE_FILE})
include_directories(${LASLIB_INCLUDE_DIR})
include_directories(${LASZIP_INCLUDE_DIR})
else()
message(STATUS "NOTICE : the LAS reader test requires LASlib and will not
be compiled.")
endif()
# include for local directory
# include for local package
# Creating entries for target: dsm
add_executable( dsm dsm.cpp )
add_to_cached_list( CGAL_EXECUTABLE_TARGETS dsm )
# Link the executable to CGAL and third-party libraries
target_link_libraries(dsm PRIVATE CGAL::CGAL )
target_link_libraries(dsm PUBLIC ${LASLIB_LIBRARIES})
