cgal-discuss - Re: [cgal-discuss] Reading a las file.
  • To: "" <>
  • Subject: Re: [cgal-discuss] Reading a las file.
  • Date: Thu, 24 Sep 2020 14:44:02 +0000
  • Accept-language: en-US
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=northeastern.edu; dmarc=pass action=none header.from=northeastern.edu; dkim=pass header.d=northeastern.edu; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=rWLVbMQ38n24AXeRhyPI+oW1kakdJuDVhLmnMtj4a2o=; b=YtQS+RXg0mMDDW/AMXtwxxmFq0ruY76n6T8+Kr0fsoIjq7u4if+i2YlWH9YqT5smIjMLyKqJC3E5krBjAKHADWbTtC612g4PYdsbtDl9PqGvIznReACPtBd1QYaTIh7yCS7jKypDnX/wzDUHSFhuqfJ2lbcQP8c3Hvuw11z4Q+Alua+5u5Giey5yea8NeIXLg81g/uS6mhmh3y1iORKVnodMcxWTbTmfR53x11pgzkMtJwKxrU7FJSro+jTNq9xumq7zhP0zJ1nsynTobP1t6jsqTlXgbdmwyoBIL+6t08V05/oX5lYxmundf6GIleHQABFmdLDIpFeFUre6j8k5SQ==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=lPLFFu7PoGKO8ffV7jOIBYSUYAsMroMOQuWpTolYfrCDoUkDoANqsURbvaFHbYtCU/0hrJcy4j3svguR4yEE3JGmxyGXcCyWFvkTv/0FyCl9k0XCyS1MQR5yB++bDAJIefvlFY2CGLa5Cvdk1L9ftduGKvdv2yhnTD6FON9mksDfj/oNz5VjgQfUkG8BG93zM0LsYQLPKogMQ5UU+xcG5gsMF7j+KWNmdULhrdVZ3PPV1xlBYxiEsBvYwEx0JyyPmI8HfnbfQCGm5IZVxm4e+gJRQl0Dqo866Dcq+Z6EKpAU3UYVvqM7D9JaWEmyvRb2RblCNJnHK4l8tTTaZrZmDQ==
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
  • Ironport-phdr: 9a23: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
I am using 5.1
It is NOTICE : the LAS reader found.
Regards,
Himanshu
Sent: Thursday, September 24, 2020 10:21 AM
To: <>
Actually it depends on your version of CGAL. <5.1, your code is probably right, if LASLIB_FOUND is TRUE. What is your CMAKE output during configuration ?
or
NOTICE : the LAS reader test requires LASlib and will not be compiled.
Le jeu. 24 sept. 2020 à 16:11, Himanshu Sharma <> a écrit :
I see. I have attached the CMakeLists.txt along.
I tried to follow CMakeLists.txt of read_las_example from Point_set_processing_3, but didnt get it right it seems.
Regards
Himanshu
Sent: Thursday, September 24, 2020 2:13 AM
To: <>
Hello,
It looks like you did not link with LAS. Can you provide your CMakeLists.txt ? You must have forgotten to link with the target CGAL::LASLIB_support. Have a look here : https://doc.cgal.org/latest/Manual/thirdparty.html#thirdpartyLASlib
Le jeu. 24 sept. 2020 à 05:27, Himanshu Sharma <> a écrit :
Hello,
I am trying to read a .las file into Point_set_3. Below is the code snippent. However this throws following error:
error: no matching function for call to 'make_las_point_reader.
I am not sure what goes wrong here. I understand that the argument to the make_las_point_reader is not of the right type.
std::ifstream ifile (argv[1], std::ios_base::binary);
  CGAL::Point_set_3<Point_3> points;
  if (!CGAL::read_las_points
      (ifile,
       points.index_back_inserter(),
       CGAL::make_las_point_reader(points.point_map())))
      std::cerr << "Error: cannot read file " << argv[1] << std::endl;
      return EXIT_FAILURE;
Regards
Himanshu
