- To:
- Subject: Re: [cgal-discuss] Reading a las file.
- Date: Thu, 24 Sep 2020 16:50:32 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
Did you include <CGAL/IO/read_las_points.h> ?
Le jeu. 24 sept. 2020 à 16:44, Himanshu Sharma <> a écrit :
Sorry, I am using 5.0 i meant.
Sent: Thursday, September 24, 2020 10:44 AM
To: <>
Subject: Re: [cgal-discuss] Reading a las file.I am using 5.1It is NOTICE : the LAS reader found.
Regards,
Himanshu
Sent: Thursday, September 24, 2020 10:21 AM
To: <>
Subject: Re: [cgal-discuss] Reading a las file.Actually it depends on your version of CGAL. <5.1, your code is probably right, if LASLIB_FOUND is TRUE. What is your CMAKE output during configuration ?NOTICE : the LAS reader found.orNOTICE : the LAS reader test requires LASlib and will not be compiled.?
Le jeu. 24 sept. 2020 à 16:11, Himanshu Sharma <> a écrit :
I see. I have attached the CMakeLists.txt along.
I tried to follow CMakeLists.txt of read_las_example from Point_set_processing_3, but didnt get it right it seems.
RegardsHimanshu
Sent: Thursday, September 24, 2020 2:13 AM
To: <>
Subject: Re: [cgal-discuss] Reading a las file.Hello,
It looks like you did not link with LAS. Can you provide your CMakeLists.txt ? You must have forgotten to link with the target CGAL::LASLIB_support. Have a look here : https://doc.cgal.org/latest/Manual/thirdparty.html#thirdpartyLASlib
Le jeu. 24 sept. 2020 à 05:27, Himanshu Sharma <> a écrit :
Hello,
I am trying to read a .las file into Point_set_3. Below is the code snippent. However this throws following error:
error: no matching function for call to 'make_las_point_reader.
I am not sure what goes wrong here. I understand that the argument to the make_las_point_reader is not of the right type.
std::ifstream ifile (argv[1], std::ios_base::binary);
CGAL::Point_set_3<Point_3> points;
if (!CGAL::read_las_points
(ifile,
points.index_back_inserter(),
CGAL::make_las_point_reader(points.point_map())))
std::cerr << "Error: cannot read file " << argv[1] << std::endl;
return EXIT_FAILURE;
RegardsHimanshu
- [cgal-discuss] Reading a las file., Himanshu Sharma, 09/24/2020
- Re: [cgal-discuss] Reading a las file., Maxime Gimeno, 09/24/2020
- Re: [cgal-discuss] Reading a las file., Himanshu Sharma, 09/24/2020
- Re: [cgal-discuss] Reading a las file., Andreas Fabri, 09/24/2020
- Re: [cgal-discuss] Reading a las file., Maxime Gimeno, 09/25/2020
