- To: "" <>
- Subject: Re: [cgal-discuss] Reading a las file.
- Date: Thu, 24 Sep 2020 14:44:14 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=northeastern.edu; dmarc=pass action=none header.from=northeastern.edu; dkim=pass header.d=northeastern.edu; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=uRHe9j7I+PQpc4ecTxd5ryPsE9ksAfKAbID4sf8Xh5E=; b=ErBTQfuO6y/K/tZpKs1nl/+8Q3ldL9No8opvCwqijiaUrS/2wxGIA4OdsK0bWIA9e2l367mSmLegrB6/YTicLNQEHe9ydXMsQVcfy7F4n0Uy4FZfETuoVyMqy1YRShnyidCfxbpJTknenj0Hr2h0oV90d9z65gquonR/qujcEnH5HEdmJANus9Uz93Hxm+hLcguV/5UZGdXvy/yQ2KQOB+KyOmHkWTymBDH07pVmvBMj79bqSNIbhp9h2K8ZQhnu+F4iky17LOQ5lDtWuETAGsPAfT41vEEHpkOK7Et1AaA2kwCvZqDgEphcC3ktHXPmSYoMCr3Nay6YTP6xuK89Rg==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=EaTENFe5ctsluPruaD5lBSvG1SBNbAM++TipOAvUmFA7m7X5fWosIpb6MlUyH8BxxmbW53xhbWiD0jCAuhA6q6F4JuqBcR2c/XHtgezIlf/9wwKTHSjHrVdqhVgnbI6YTCkTezavuTu79D1V+ZZ+E3qYlRoIR11LQIoxy9t0HrgZk1wM21tDDyAyDg8W13vMkVQz3sgmmZ5yZsSZaFKKQBf3ARucQ98RaUA7Fz8oKND39DPrdMDnRLPTKZSiTSEUK0evokNa2wpaMc4r8ZKwUrgaS0ObnYvfP8mmI2JArUu14WbhpPzPMXqpVry5nh9Ujge+sl3DaOIaZt4rpb7Z/w==
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23: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
Sorry, I am using 5.0 i meant.
Sent: Thursday, September 24, 2020 10:44 AM
To: <>
To: <>
I am using 5.1
It is NOTICE : the LAS reader found.
Regards,
Himanshu
Himanshu
Sent: Thursday, September 24, 2020 10:21 AM
To: <>
To: <>
Actually it depends on your version of CGAL. <5.1, your code is probably right, if LASLIB_FOUND is TRUE. What is
your CMAKE output during configuration ?
or
NOTICE : the LAS reader test requires LASlib and will not be compiled.
Le jeu. 24 sept. 2020 à 16:11, Himanshu Sharma <> a écrit :
I see. I have attached the CMakeLists.txt along.
I tried to follow CMakeLists.txt of read_las_example from Point_set_processing_3, but didnt get it right it seems.
RegardsHimanshu
Sent: Thursday, September 24, 2020 2:13 AM
To: <>
Subject: Re: [cgal-discuss] Reading a las file.Hello,
It looks like you did not link with LAS. Can you provide your CMakeLists.txt ? You must have forgotten to link with the target CGAL::LASLIB_support. Have a look here : https://doc.cgal.org/latest/Manual/thirdparty.html#thirdpartyLASlib
Le jeu. 24 sept. 2020 à 05:27, Himanshu Sharma <> a écrit :
Hello,
I am trying to read a .las file into Point_set_3. Below is the code snippent. However this throws following error:
error: no matching function for call to 'make_las_point_reader.
I am not sure what goes wrong here. I understand that the argument to the make_las_point_reader is not of the right type.
std::ifstream ifile (argv[1], std::ios_base::binary);
CGAL::Point_set_3<Point_3> points;
if (!CGAL::read_las_points
(ifile,
points.index_back_inserter(),
CGAL::make_las_point_reader(points.point_map())))
std::cerr << "Error: cannot read file " << argv[1] << std::endl;
return EXIT_FAILURE;
RegardsHimanshu
- [cgal-discuss] Reading a las file., Himanshu Sharma, 09/24/2020
- Re: [cgal-discuss] Reading a las file., Maxime Gimeno, 09/24/2020
- Re: [cgal-discuss] Reading a las file., Himanshu Sharma, 09/24/2020
- Re: [cgal-discuss] Reading a las file., Andreas Fabri, 09/24/2020
- Re: [cgal-discuss] Reading a las file., Maxime Gimeno, 09/25/2020
