- To: "" <>
- Subject: [cgal-discuss] Help to build from vcpkg
- Date: Wed, 13 Jan 2021 21:41:47 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=epmap-system.com; dmarc=pass action=none header.from=epmap-system.com; dkim=pass header.d=epmap-system.com; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=wJa1AtDcxCPtBfDWnssFzbC9s8j6vQF4+awiM2R62VI=; b=im0L/t+0X4ffADIK0lWhJaf9r7+mg/CzynlO0CM7ETTfZJXzThIS3nPa9tQN3+7ZW+IdPSSn6mVeMRMT8s2lygal+qdvqVeVDHSnL99wkrwUCbjZtMR+e2UOYiaYwuDVx4vnoNp8Nty18Lo8StQR21hWtewcfh6yjTDg1yZ2p30BaOz43kbY0k1/eG/8+JLuYx4wGNtHx+6KQEp34Y0dbRNj6l2+NNbnVR8AnQmEmhcjYgkBKzJf2QPNn02Yx5k/mSGCkl1sa+/EHaE6qgHBWv4gXyLPDu3ebfBDIOP8jVWxrtdBtuF1NYsWLDhAc/pUqzRxP6Somj2lHY9ITCzHtA==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=U/1IZNlTuvhnalkrPqHRo0pTwl0J2v3l/2iHO6H3r4h3fEqSDEL+kJyHMat06/dxX40j6IhJSoYuXDUAydoMrGCqhVfIbSOPz7M4LxE+UpK9XX+Tsx7zkDcVPcFwPWhSbfuYsuL3gA6/7g/jwrs5WD9/cTRta4A2YwnIB6MaEpoA7HTsE7jdE2XI8SNop4cchzNPk476VtLhfKOppi5Apil1Hi74FG9hfCzozLAsEG1nMqXGYoQHkX+rTCrjjhfjc6BEFyZ6F/Jp4hAm1h/KkcYVlgDsmVZnDuRTxyXNUpGH/bacHwIHWbkFmUUJFezXwIz5KOHDgLeSaivVd4mE9g==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23: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
I am trying to build and use CGAL by using the vcpkg tool.
Everything has installed without error.
But when compiling my code, which is mostly the example code taken from Mesh_3/mesh_3D_gray_image.cpp,
I have the following error coming from ls_mesh_domain_field_3.h
Cannot open include file: 'boost/callable_traits/is_invocable.hpp': No such file or directory
Thank you
- [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/13/2021
- Re: [cgal-discuss] Help to build from vcpkg, Maxime Gimeno, 01/14/2021
- Re: [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/14/2021
- Re: [cgal-discuss] Help to build from vcpkg, Maxime Gimeno, 01/15/2021
- Re: [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/15/2021
