- To:
- Subject: Re: [cgal-discuss] Help to build from vcpkg
- Date: Fri, 15 Jan 2021 09:16:51 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
As you can see here : https://github.com/boostorg/callable_traits/tree/boost-1.75.0/include/boost/callable_traits
your missing header is still here in boost 1.75. Furthermore, our testsuite doesn't show your error. So either you are missing a cmake step, like a boost component, or the boost in vcpkg is buggy.
Le jeu. 14 janv. 2021 à 17:29, Tony Apicella <> a écrit :
The compiler is finding boost. But the vcpkg build is installing boost 1.75, and these files have been removed that version. When I switch boost to version 1.69 then I can build.
Sent: Wednesday, January 13, 2021 11:58 PM
To: <>
Subject: Re: [cgal-discuss] Help to build from vcpkgIt seems your compiler cannot find boost. Did you give a valid path to cmake for Boost_DIR or BOOST_ROOT ?
Le mer. 13 janv. 2021 à 22:42, Tony Apicella <> a écrit :
I am trying to build and use CGAL by using the vcpkg tool.Everything has installed without error.
But when compiling my code, which is mostly the example code taken from Mesh_3/mesh_3D_gray_image.cpp,I have the following error coming from ls_mesh_domain_field_3.h
Cannot open include file: 'boost/callable_traits/is_invocable.hpp': No such file or directory
Thank you
- [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/13/2021
- Re: [cgal-discuss] Help to build from vcpkg, Maxime Gimeno, 01/14/2021
- Re: [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/14/2021
- Re: [cgal-discuss] Help to build from vcpkg, Maxime Gimeno, 01/15/2021
- Re: [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/15/2021
