cgal-discuss - Re: [cgal-discuss] Help to build from vcpkg
  • To:
  • Subject: Re: [cgal-discuss] Help to build from vcpkg
  • Date: Fri, 15 Jan 2021 15:11:00 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
  • Ironport-phdr: 9a23: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
I thought it was Boost_DIR since 1.70
Le ven. 15 janv. 2021 à 15:05, Tony Apicella <> a écrit :
Thank you.  vcpkg didn't copy some of the files in the BOOST_ROOT directory.
Sent: Friday, January 15, 2021 12:16 AM
To: <>
As you can see here : https://github.com/boostorg/callable_traits/tree/boost-1.75.0/include/boost/callable_traits
your missing header is still here in boost 1.75. Furthermore, our testsuite doesn't show your error. So either you are missing a cmake step, like a boost component, or the boost in vcpkg is buggy.
Le jeu. 14 janv. 2021 à 17:29, Tony Apicella <> a écrit :
The compiler is finding boost.  But the vcpkg build is installing boost 1.75, and these files have been removed that version.  When I switch boost to version 1.69 then I can build.
Sent: Wednesday, January 13, 2021 11:58 PM
To: <>
It seems your compiler cannot find boost. Did you give a valid path to cmake for Boost_DIR or BOOST_ROOT ?
Le mer. 13 janv. 2021 à 22:42, Tony Apicella <> a écrit :
I am trying to build and use CGAL by using the vcpkg tool.
Everything has installed without error.
But when compiling my code, which is mostly the example code taken from Mesh_3/mesh_3D_gray_image.cpp,
I have the following error coming from ls_mesh_domain_field_3.h
Cannot open include file: 'boost/callable_traits/is_invocable.hpp': No such file or directory
Thank you
