- To:
- Subject: Re: [cgal-discuss] Help to build from vcpkg
- Date: Thu, 14 Jan 2021 08:58:02 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=None
- Ironport-phdr: 9a23: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
It seems your compiler cannot find boost. Did you give a valid path to cmake for Boost_DIR or BOOST_ROOT ?
Le mer. 13 janv. 2021 à 22:42, Tony Apicella <> a écrit :
I am trying to build and use CGAL by using the vcpkg tool.Everything has installed without error.
But when compiling my code, which is mostly the example code taken from Mesh_3/mesh_3D_gray_image.cpp,I have the following error coming from ls_mesh_domain_field_3.h
Cannot open include file: 'boost/callable_traits/is_invocable.hpp': No such file or directory
Thank you
- [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/13/2021
- Re: [cgal-discuss] Help to build from vcpkg, Maxime Gimeno, 01/14/2021
- Re: [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/14/2021
- Re: [cgal-discuss] Help to build from vcpkg, Maxime Gimeno, 01/15/2021
- Re: [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/15/2021
