- To: "" <>
- Subject: Re: [cgal-discuss] Help to build from vcpkg
- Date: Fri, 15 Jan 2021 14:05:16 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=epmap-system.com; dmarc=pass action=none header.from=epmap-system.com; dkim=pass header.d=epmap-system.com; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=VBTgln51jFrvUHIRSNK8dj55t14u35JWb3g1pCW8hV4=; b=fyu3NsWTKEA3KK1z1zU+wVrOxNGoAbXSeLahnxFJw830Qv631eLQF/j3SZInr5KhMdnrG77IL7+vPisLCLOhe0jWgP5EdyWb4AbxYkRVyNK3DL8jsBUura17LGfSMJNeneJqzxbfRR3CLw+b2MkPlGlGDlA1FS5/FeL4bvJ6ak50Lv3Ek8MDGyQrYfnN6wW9RFmiAaJ1EWSJmjATXEGDIRqyc3i9/Dx4r1PCYz0cKuv2UuQFiOBTn+HMoWc4hhypbMgtNoCjWvqFkp9WVH8MOT9zxR27AF3S8/f3DMFb9CwLec+DvIs5Elj6gIwWW77HKKqWemfTcz0F61XMNh5d+Q==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=nr+SO0YQLDaSMojgQqPdr7++bUs+yPbn6QvdXrxDWi7ouMIHsSr4Lrw+7oAcZkWs+xPwLG/6UgJJWIt6G/cmLCb4Xi8Cym7vzZPTfd7tjr6OE6KDt/KDK1rb0rGg9IRsyBlNlc9HQUPM1l+Sv7KmlEi7PIsD5lwmKcTaCTTSvDrFUIaf9iElo0a6y1ZV/XlcfyFMpc0J0mdRe+VfMeXuxIAvH1REcuPDNXzknncLrt9ap54QvHP13ANkBHy6illhkse2BX8ZvYxtD8jt8500BRQMd+AY2F10XfEESwX7mn50HPYeYz59QLHwQp23fbhxlG18PX41cZ96y0g+LnSzVw==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None ; spf=Pass ; spf=Pass
- Ironport-phdr: 9a23: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
Thank you. vcpkg didn't copy some of the files in the BOOST_ROOT directory.
Sent: Friday, January 15, 2021 12:16 AM
To: <>
To: <>
As you can see here :
https://github.com/boostorg/callable_traits/tree/boost-1.75.0/include/boost/callable_traits
your missing header is still here in boost 1.75. Furthermore, our testsuite doesn't show your error. So either you are missing a cmake step, like a boost component, or the boost in vcpkg is buggy.
Le jeu. 14 janv. 2021 à 17:29, Tony Apicella <> a écrit :
The compiler is finding boost. But the vcpkg build is installing boost 1.75, and these files have been removed that version. When I switch boost to version 1.69 then I can build.
Sent: Wednesday, January 13, 2021 11:58 PM
To: <>
Subject: Re: [cgal-discuss] Help to build from vcpkgIt seems your compiler cannot find boost. Did you give a valid path to cmake for Boost_DIR or BOOST_ROOT ?
Le mer. 13 janv. 2021 à 22:42, Tony Apicella <> a écrit :
I am trying to build and use CGAL by using the vcpkg tool.Everything has installed without error.
But when compiling my code, which is mostly the example code taken from Mesh_3/mesh_3D_gray_image.cpp,I have the following error coming from ls_mesh_domain_field_3.h
Cannot open include file: 'boost/callable_traits/is_invocable.hpp': No such file or directory
Thank you
- [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/13/2021
- Re: [cgal-discuss] Help to build from vcpkg, Maxime Gimeno, 01/14/2021
- Re: [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/14/2021
- Re: [cgal-discuss] Help to build from vcpkg, Maxime Gimeno, 01/15/2021
- Re: [cgal-discuss] Help to build from vcpkg, Tony Apicella, 01/15/2021
