- To: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
- Subject: RE: [Coq-Club] Transitivity for a non-standard subtyping relation
- Date: Sun, 14 Jun 2009 01:45:13 -0700
- Accept-language: en-US
- Acceptlanguage: en-US
(* Thanks Adam and Matthew (and everyone else) for taking a look at
this. I hope the following sketch and example convey better the
essence of my problem.
Here's an informal statement and (incomplete) proof sketch of my
lemma:
Lemma 1: forall a a' t1 t2 t3,
(D1) relate a t1 t2
(D2) relate a' t2 t3
=> relate Fun t1 t3
By induction on the structure of (D1), the interesting case is when
(D1) is an application of (Rel_fun), as shown below:
(D1.1) relate a s1 t1
(D1.2) relate a' t1' s1'
(D1.3) relate NoFun (typ_fun s1 s1') t2
-------------------------------------------------------- [D1]
relate Fun (typ_fun t1 t1') t2
From the induction hypothesis applied to D1.3 and D2 we get
(D2') relate Fun (typ_fun s1 s1') t3.
Now, by inversion on (D2'), we get the following interesting case:
(D2'.1) relate b r1 s1
(D2'.2) relate b' s1' r1'
(D2'.3) relate NoFun (typ_fun r1 r1') t3
----------------------------------------------------- [D2']
Now, the goal is to construct (relate Fun (typ_fun t1 t1') t3). We
can do this by using Rel_fun, to first take a "step" to
(typ_fun r1 r1') and then to use (D2'.3) to complete the derivation.
I can use the induction hypothesis on (D1.2) and (D2'.2) to construct
(G.2) (relate Fun t1' r1')
Similarly, I'd like to use the induction hypothesis on (D1.1) and
(D2'.1) to construct:
(G.1) (relate Fun r1 t1)
So, now I can construct:
(D2'.3) (relate NoFun (typ_fun r1 r1') t3)
----------------------------------------------------------- [Goal]
However, this doesn't quite work in Coq because the induction
hypothesis on (D1.1) only applies to derivations that "extend D1.1
to the right", i.e., derivations that are of the form (relate a t1
x) and not (relate a x s1), which is what we have in (D2'.1).
My thought at this point was to attempt to prove a version of this
transitivity lemma in which extending a derivation both "to the
right" and "from the left" is explicitly included in the induction
hypothesis. I.e, something like:
Lemma 2: forall a a' a'' t0 t1 t2 t3,
(D1) relate a t1 t2
(D3) relate a'' t0 t1
=> relate Fun t1 t3 /\ relate Fun t0 t2
But, from my previous posting, you will see that I get stuck in
carrying out this proof because I reach a point where I have
and
(D3) (relate a t0 (typ_fun t1 t1'))
and need to show (relate Fun t0 t).
In order to do this, what I really want to do is inspect the "last
step" of (D3) and in the case where it is of the following form,
(relate Fun (typ_fun r1 r1') (typ_fun t1 t1'))
I want to construct a
(relate Fun (typ_fun r1 r1') (typ_fun s1 s1'))
using the premises of D1 and D3, and the induction hypotheses.
However, I don't have a way of inverting/inducting on (D3) so that
I can inspect the tail of the derivation.
In case this handwaving is too confusing, I'm including a variation
of my system below in which I have replaced the contravariance of
relate in the argument of a function with covariance. I state and
prove the transitivity lemma (a version of Lemma 1 above) for this
altered system. I hope this also helps provide some intuitions for
this system.
Again, many thanks for taking the time to look at this. I really
appreciate your help!
--Nik
Require Import List.
Inductive typ : Type :=
| typ_atom : nat -> typ
| typ_fun : typ -> typ -> typ.
Inductive alt : Type :=
| Fun
| NoFun.
Notation prims := (list (typ * typ)).
Inductive relate : prims -> alt -> typ -> typ -> Prop :=
| Rel_id : forall P a t,
relate P a t t
| Rel_trans: forall P a a' t1 t2 t3,
(In (t1, t2) P) ->
(relate P a t2 t3) ->
(relate P a' t1 t3)
| Rel_fun: forall P a a' t1 t2 t1' t2' t,
(relate P a t1 t1') -> (* Note the change from the previous version---no
longer contravariant *)
(relate P a' t2 t2') ->
(relate P NoFun (typ_fun t1' t2') t) ->
(relate P Fun (typ_fun t1 t2) t).
Hint Constructors relate.
Lemma relate_trans: forall P a1 a2 t1 t2 t3,
(relate P a1 t1 t2) ->
(relate P a2 t2 t3) ->
(exists a, relate P a t1 t3).
intros P a1 a2 t1 t2 t3 P12 P23.
generalize dependent a2.
generalize dependent t3.
induction P12.
(* Case id *)
intros; eauto.
(* Case trans *)
intros.
destruct (IHP12 _ _ P23) as [aa tail].
exists Fun. eauto.
(* Case fun *)
intros.
destruct (IHP12_3 _ _ P23) as [aa tail].
clear IHP12_3.
inversion tail.
(* Case tail is id *)
subst. exists Fun. eauto.
(* Case tail is trans *)
(* Case tail is fun -- the interesting case *)
subst.
rename H6 into tail_of_tail.
rename H1 into tail_arg.
rename H4 into tail_ret.
(* The two adjacent applications of Rel_fun,
first from (typ_fun t1 t2) to (typ_fun t1' t2') in P12
and then from (typ_fun t1' t2') to (typ_fun t1'0 t2'0) in tail
can be collapsed into a single application of Rel_fun by
composing P12_1 and tail_arg, and P12_2 with tail_ret *)
destruct (IHP12_1 _ _ tail_arg) as [a_arg arg].
destruct (IHP12_2 _ _ tail_ret) as [a_ret ret].
exists Fun.
eauto.
Qed.
> -----Original Message-----
> From: Matthew Brecknell
> [mailto:matthew AT brecknell.net]
> Sent: Saturday, June 13, 2009 11:23 PM
> To: Nikhil Swamy
> Cc:
> Subject: Re: [Coq-Club] Transitivity for a non-standard subtyping
> relation
> I wrote:
> > (* However, if subtype-relatedness (according to the way you've
> defined
> > it) really is transitive, it should be possible to show the
> following,
> > but I don't see how to do it: *)
> Silly me, I see it now:
> Lemma rel_fun_ba_ab: relate P Fun (typ_fun b a) (typ_fun a b).
> apply Rel_fun with NoFun NoFun a b; auto; constructor.
> Qed.
> So I guess that brings me no closer to understanding your problem.
> Sigh...
- [Coq-Club] Transitivity for a non-standard subtyping relation, Nikhil Swamy
- Re: [Coq-Club] Transitivity for a non-standard subtyping relation, Adam Chlipala
Matthew Brecknell
Matthew Brecknell
- RE: [Coq-Club] Transitivity for a non-standard subtyping relation, Nikhil Swamy
Adam Chlipala
Nikhil Swamy
Adam Chlipala
- Message not available
Adam Chlipala
Nikhil Swamy
Adam Chlipala
Matthew Brecknell
- [Coq-Club] Module Types,
Cedric Auger
- Re: [Coq-Club] Module Types,
Elie Soubiran
- Re: [Coq-Club] Module Types, Cedric Auger
Elie Soubiran
