- Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Module Types
- Date: Fri, 19 Jun 2009 13:17:46 +0200
Elie Soubiran a écrit :
Hello Cedric,The user has already to do that with lambda terms, so having to do this for proofs as well is not a matter...
In my opinion, it is forbidden because you could easily build two different proofs for a given lemma (using automation for example).
(* runs only on a hacked version of Coq *)
Require Omega.
Module Type S.
Lemma foo : 1+1= 2.
omega.
Qed.
End S.
Module M : S.
Lemma foo : 1+1 = 2.
reflexivity.
Qed.
End M.
(* Error: Signature components for label foo do not match.*)
Maybe this restriction is not relevant, we should rather let the user takes care of building the same proof in the signature and in the implementation.
Elie
On Thu, Jun 18, 2009 at 6:29 PM, Cedric Auger <Cedric.Auger AT lri.fr <mailto:Cedric.Auger AT lri.fr>> wrote:
Hi all,
Is there any special reason to forbide the proof-editing mode in
Module Types and allow Definitions?
Since the proof editing mode is just a way to build Definitions, I
don't see the reason to allow directly writing lambda terms but
not to use the tools to build them.
-- Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
Cédric AUGER
- Re: [Coq-Club] Transitivity for a non-standard subtyping relation, (continued)
Matthew Brecknell
Matthew Brecknell
- RE: [Coq-Club] Transitivity for a non-standard subtyping relation,
Nikhil Swamy
Adam Chlipala
Nikhil Swamy
Adam Chlipala
- RE: [Coq-Club] Transitivity for a non-standard subtyping relation, Nikhil Swamy
- Message not available
Adam Chlipala
Nikhil Swamy
Adam Chlipala
Nikhil Swamy
Matthew Brecknell
- [Coq-Club] Module Types,
Cedric Auger
- Re: [Coq-Club] Module Types,
Elie Soubiran
- Re: [Coq-Club] Module Types, Cedric Auger
Elie Soubiran
Matthew Brecknell
