- To: Nikhil Swamy <nswamy AT microsoft.com>
- Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
- Subject: Re: [Coq-Club] Transitivity for a non-standard subtyping relation
- Date: Sun, 14 Jun 2009 17:43:38 -0400
Nikhil Swamy wrote:
However, I wonder if there is some more standard idiomatic way of
handling a situation like this. Ideally something that doesn't require
me having to pollute my definitions with this counter instrumentation.
Well, did you try proving a lemma analogous to the one I gave, but for the other "stuck" case from the original proof? If that works, it avoids changing the definition of the relation.
Also, you will notice that my proof script is not very readable at all
:( I end up doing a lot of things manually, e.g, at various points
when I use eauto I'm left with uninstantiated existential variables,
so I often have to provide explicit parameters to eapply. Any tips for
how to avoid this and/or to make my proof more readable would be
great!
At that point, you can run [Show Proof] to see where those evars came from. I bet you could avoid most such problems by changing your relation definition, or defining another version that you prove equivalent. I recommend removing the quantification over [a] values for any sub-judgments. Instead, just require a [Fun] proof for every sub-judgment. You can prove a lemma that any [NoFun] proof can be converted to a [Fun] proof.
- [Coq-Club] Transitivity for a non-standard subtyping relation, Nikhil Swamy
- Re: [Coq-Club] Transitivity for a non-standard subtyping relation, Adam Chlipala
Matthew Brecknell
Matthew Brecknell
- RE: [Coq-Club] Transitivity for a non-standard subtyping relation,
Nikhil Swamy
Adam Chlipala
Nikhil Swamy
- RE: [Coq-Club] Transitivity for a non-standard subtyping relation, Nikhil Swamy
- Message not available
Nikhil Swamy
Adam Chlipala
Nikhil Swamy
Matthew Brecknell
- [Coq-Club] Module Types,
Cedric Auger
- Re: [Coq-Club] Module Types,
Elie Soubiran
- Re: [Coq-Club] Module Types, Cedric Auger
Elie Soubiran
