coq-club - RE: [Coq-Club] Transitivity for a non-standard subtyping relation
chronological Thread
  • To: Adam Chlipala <adamc AT hcoop.net>
  • Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: RE: [Coq-Club] Transitivity for a non-standard subtyping relation
  • Date: Sun, 14 Jun 2009 15:07:01 -0700
  • Accept-language: en-US
  • Acceptlanguage: en-US
> > However, I wonder if there is some more standard idiomatic way of
> > handling a situation like this. Ideally something that doesn't
> require
> > me having to pollute my definitions with this counter
> instrumentation.
> Well, did you try proving a lemma analogous to the one I gave, but for
> the other "stuck" case from the original proof?  If that works, it
> avoids changing the definition of the relation.
I had a lemma very similar to the one you gave. However, the analogous lemma
for the Rel_fun case doesn't work out easily, since it must itself rely on
transitivity. For example, you could try to show
forall P a t t1 t2 t1' t2,
         (relate P a t (typ_fun t1 t2)) ->
         (relate P a t1' t1) ->
         (relate P a t2 t2') ->
         (relate P a t (typ_fun t1' t2')
However, showing this requires proving that the sub-derivations that appear
in the premises of the first derivation can be transitively composed with the
second and third derivations.
Anyway, thanks very much for your help. I can get away without using these
counters in my real system. So, although I'd be interested to see if there
was a way to do this without using counters, I am not too concerned for the
moment.
--Nik
> > Also, you will notice that my proof script is not very readable at
> all
> > :( I end up doing a lot of things manually, e.g, at various points
> > when I use eauto I'm left with uninstantiated existential variables,
> > so I often have to provide explicit parameters to eapply. Any tips
> for
> > how to avoid this and/or to make my proof more readable would be
> > great!
> At that point, you can run [Show Proof] to see where those evars came
> from.  I bet you could avoid most such problems by changing your
> relation definition, or defining another version that you prove
> equivalent.  I recommend removing the quantification over [a] values
> for
> any sub-judgments.  Instead, just require a [Fun] proof for every
> sub-judgment.  You can prove a lemma that any [NoFun] proof can be
> converted to a [Fun] proof.
