coq-club - Re: [Coq-Club] Module Types
chronological Thread
  • From: Elie Soubiran <soubiran AT lix.polytechnique.fr>
  • To: Cedric Auger <Cedric.Auger AT lri.fr>
  • Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Module Types
  • Date: Fri, 19 Jun 2009 12:36:57 +0200
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=mime-version:sender:in-reply-to:references:date :x-google-sender-auth:message-id:subject:from:to:cc:content-type; b=PmncnHw4SqCFj9DPmjsPpM9PLaACJB2nW5DRoz0jG34ZHmTLjbkxf3NPWO2HwQ89c7 IA8DuT0vB92DwJADBvVtUXwOG07DKhSGUGe8mUtXyuplR+i6i5kHDHloahjEvsriInwK l1Y1i+BDAj0bc6VX1sgAHSlJ/zHtCFOBSENWc=
Hello Cedric,
In my opinion, it is forbidden because you could easily build two different proofs for a given lemma (using automation for example).
(* runs only on a hacked version of Coq *)
Require Omega.
Module Type S.
  Lemma foo : 1+1= 2.
   omega.
  Qed.
End S.
Module M : S.
  Lemma foo : 1+1 = 2.
    reflexivity.
  Qed.
End M.
 (* Error: Signature components for label foo do not match.*)
Maybe this restriction is not relevant, we should rather let the user takes care of building the same proof in the signature and in the implementation.
Elie
On Thu, Jun 18, 2009 at 6:29 PM, Cedric Auger <Cedric.Auger AT lri.fr> wrote:
Hi all,
Is there any special reason to forbide the proof-editing mode in Module Types and allow Definitions?
Since the proof editing mode is just a way to build Definitions, I don't see the reason to allow directly writing lambda terms but not to use the tools to build them.
Cédric AUGER
Univ Paris-Sud, Laboratoire LRI, UMR 8623, F-91405, Orsay
Bug reports: http://logical.saclay.inria.fr/coq-bugs
Archives: http://pauillac.inria.fr/pipermail/coq-club
        http://pauillac.inria.fr/bin/wilma/coq-club
Info: http://pauillac.inria.fr/mailman/listinfo/coq-club
