coq-club - Re: [Coq-Club] Transitivity for a non-standard subtyping relation
chronological Thread
  • To: Nikhil Swamy <nswamy AT microsoft.com>
  • Cc: "coq-club AT pauillac.inria.fr" <coq-club AT pauillac.inria.fr>
  • Subject: Re: [Coq-Club] Transitivity for a non-standard subtyping relation
  • Date: Sun, 14 Jun 2009 11:19:31 -0400
(* Here's a lemma that makes it easy to solve the first of the "stuck" cases from your original post. *)
Lemma Rel_prim : forall P a t1 t2,
 In (t1, t2) P
 -> relate P a t1 t2.
 intros; apply Rel_trans with NoFun t2; auto.
Qed.
Hint Immediate Rel_prim.
Lemma relate_append : forall P a t0 t1 t2,
 relate P a t0 t1
 -> In (t1, t2) P
 -> relate P a t0 t2.
 induction 1; eauto.
Qed.
(* I don't think this kind of manipulation could be passed off as "inversion" even in a pencil-and-paper proof, so I don't think this problem has much to do with Coq. You would really need to prove this lemma inductively in any case, right? *)
Nikhil Swamy wrote:
Lemma relate_trans: forall P a1 a2 a3 t0 t1 t2 t3, (relate P a1 t1 t2) -> (relate P a2 t2 t3) -> (relate P a3 t0 t1) -> (exists a, relate P a t1 t3) /\ (exists a, relate P a t0 t2).
Proof.
intros P a1 a2 a3 t0 t1 t2 t3 P12 P23 P01.
generalize dependent t3.
generalize dependent a2.
generalize dependent t0.
generalize dependent a3.
induction P12.
  (* Case id *)
  intros. eauto.
(* Case Rel_trans *)
  intros.
  assert ((exists a : alt, relate P a t2 t4) /\
          (exists a : alt, relate P a t2 t3)) as [[m_fwd D_fwd] [m_useless
D_useless]].
     eapply IHP12; eauto.
split. (* Sub-case: extending to the right *)
     exists Fun. eauto.
     (* Sub-case: extending from the left *)
     (* Stuck:
              How can I construct (relate P a3 t0 t2) from
              H and P01 to use IHP12?
              Inverting on P01 only allows me to inspect the "head"
              of the derivation, not the "tail", which is what I need
              to tack on the (t1, t2) primitive relation at the end of
              P01.
