coq-club - Re: [Coq-Club] Re: Universe Polymorphism
chronological Thread
  • To: Andreas Abel <andreas.abel AT ifi.lmu.de>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Re: Universe Polymorphism
  • Date: Tue, 14 Sep 2010 14:07:07 -0400
  • Domainkey-signature: a=rsa-sha1; c=nofws; d=gmail.com; s=gamma; h=from:to:subject:date:user-agent:cc:references:in-reply-to :mime-version:content-type:content-transfer-encoding:message-id; b=KjMTyrEA3KV2QMzsD2yWDPqyAA5ox34ril5X+dyKBW2xtRsiyoWGMq4XJcgGMoE+k4 dyGXpnxv4S5sfSJ5+UBW2K3wR3dGieRyodX3UOlJlJzwbYmfK/tnb8073pt2/yMZeOSM yWFMw7cL3gK8MBpDfXqJSS/8GWtGZEFifZ1rw=
On Tuesday 14 September 2010 8:56:30 am Andreas Abel wrote:
> This ensures that levels remain irrelevant for
> computation, they are only there to sort out the universe
> stratification.  This is in analogy to sizes in the type-based
> termination approach: sizes are only there to sort out the
> termination, they are computationally irrelevant.
Ah. I guess this solves the gotchas I'd thought of in this regard. I knew
that
people weren't happy with Agda's having non-parametric quantification over
levels for use in Sets. However, I had thought that even without case
analysis, you could do the following:
  embed : Nat -> Level
  embed zero    = zero
  embed (suc n) = suc (embed n)
  f : (n : Nat) -> ... embed n ...
and regain non-parametric quantification (by analysis on Nat), even without
eliminators for Level. But, if Level is always irrelevent, embed is not a
valid function (if this is anything like erasure pure type systems *).
My own thoughts on the issue were a bit wackier. I've been interested in
EPTSes for a while, and came up with a way (I think), to extend them to
provide some solutions. The EPTSes in the linked paper are presented as
having
function space rules like ordinary pure type systems. But, what if we allowed
them to know whether irrelevant or relevant quantification is being
performed,
too (and for universe polymorphism, tell it what variable is being bound)?
Then rules are of the form (sticking to functional relations):
 (var, phase, sort, sort) -> sort
(that may not be an ideal presentation of the rules, but it should suffice)
The ordinary part of the hierarchy would go:
  (v, _, Set i, Set j) -> Set (lub i j) if v is not free in j
And for universe polymorphism, we can add:
  (v, c, Set i, Set j) -> Setω if v is free in j
The important part being that this only allows computationally irrelevant
function spaces to be used for universe polymorphism. This means that embed
is
now valid:
  Nat : Set 0, Level : Set 0
  rule (_, r, Set 0, Set 0) = Set 0
But, when we go to try and use it to enable non-parametric universe
dependence, we fail:
  f : (n : Nat) -> ... T : Set (embed n) ...
  f zero    = ...
  f (suc n) = ...
  Nat : Set 0, T : Set (embed n)
  rule (n, r, Set 0, Set (embed n)) = error
So, appropriate behavior is not ensured by making Level itself inherently
irrelevant, but by ensuring that only irrelevant things (regardless of type)
are used in universe polymorphism. For instance, we could instead write
(using, I think, similar notation to the irrelevance stuff you've proposed
for
Agda):
  g : .(n : Nat) -> ... T : Set (embed n) ...
  g n {- no case analysis -} = ...
(I also have another idea of where the above style rules could be useful. **)
> Note that Setω is not part of the Agda syntax, it is used
> only internally, and plays the role of "Type" in the Martin-L"of
> logical framework.
I know. Although, I think it could be useful (and non-problematic) to allow
talking about it. I have my own simple interpreter for fooling with Agda-like
universe stuff (without the irrelevance stuff I mentioned above; I haven't
gotten around to implementing something with all that yet), and it allows
sigma types like:
  (Σ i : Level. Σ T : Set i. T) : Ω
(incidentally, I also think a type not of the form SetN is kind of
appropriate
as a top, because Setω kind of makes ω look like a Level.) But you cannot
construct a similar type in Agda:
  data All : Setω where
    con : (i : Level) -> (T : Set i) -> T -> All
because that "Setω" is an error. Yet for any All -> T, the corresponding
curried function is allowed.
> I think we have a systematic and fairly simple solution to the problem
> of universe polymorphism.
I do like it. Making universe levels (roughly) ordinary, first-class values
seems simpler and more natural than a lot of other proposals I've seen. But I
can understand people being a weirded out by, essentially, Set being a family
that contains its own index/parameter type.
-- Dan
[*] http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.156.2558
[**] One redundancy of EPTSes is that quantification on Sets is probably
naturally parametric when doing (x : Set i) -> (T : Set j) i > j stuff. It is
in Agda, I believe. You could solve this redundancy by adding type case as a
language primitive. Then parametric quantification would ensure that type
case
isn't used, and types could be erased.
But, you could also use the above rules to disallow using the ordinary
function space where it's necessarily parametric, like so (ignoring variables
for now):
  (_, Set i, Set j) -> Set j if i <= j
  (c, Set i, Set j) -> Set i if i >  j
And now we can no longer write:
  id : (A : Set) -> A -> A
only:
  id : .(A : Set) -> A -> A
Forcing us to tag all the Sets that can be erased. I'm not actually certain
this is useful, since it imposes an additional burden on the programmer to
provide information the compiler could figure out, but it might be
interesting
in an intermediate language.
