coq-club - Re: [Coq-Club] Re: Universe Polymorphism
chronological Thread
  • To: Dan Doel <dan.doel AT gmail.com>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Re: Universe Polymorphism
  • Date: Thu, 16 Sep 2010 18:34:53 +0200
Dear Dan,
thanks for your answer and the pointer to the EPTS paper. I had not seen it so far, I always refer to a paper by Barras and Bernardo published at the same conference (FoSSaCS 2008) with nearly the same content!
In MiniAgda, I am using EPTSs and I started implementing them for Agda, although there are some issues to clarify when you scale up from PTSs to a real dependent type theory with types defined by cases.
- PTS rules can be used to forbid your embed function, if you put Level outside of the Set tower.
If TLevel is the sort of Level, then just do not add rules like (Set i, Level, Level).
- Then, since there are no constructors for Level, you cannot match on anything of type Level, so there is no computational dependency on Level things.
- Additionally, we can make Level quantification
  (i : Level) -> A
irrelevant, .(i : Level) -> A in future Agda syntax, [i : Level] -> A in MiniAgda syntax, as long as A is something that is inhabited by terms only (meaning that we can be sure that A is not a universe).
Finding out whether something is a universe is not completely trivial in Coq or Agda, because of types defined by cases and cumulativity. Consider this little MiniAgda program (nothing specific to MiniAgda here):
data Bool : Set 0   -- Bool  is a type
{ true  : Bool      -- true  is a term
; false : Bool      -- false is a term
fun T : Bool -> Set 1 -- T is a type (scheme)
{ T true  = Bool      -- T true is a type
; T false = Set 0     -- T false is a universe
-- cannot erase T x argument, even though T x : Set 1 and Bool : Set 0
fun weird : (x : Bool) -> T x -> Bool
{ weird false A     = false
; weird true  true  = false
; weird true  false = true
While T false is a universe, T true is just a data type. Consequently, T x, even though it is in Set 1 (and not in anything below), cannot be marked irrelevant in the type of weird. This is why, unfortunately, your idea
 (_, Set i, Set j) -> Set j if i <= j
 (c, Set i, Set j) -> Set i if i >  j
does not work.
I remember having seen somewhere [Augustsson's Cayenne? cannot find the reference] a system where each type gets both a minimum sort and a "maximum" sort (meaning a lub). Then, T x would have sort [0,1] meaning it can be a type or a universe. Marking arguments irrelevant seems to require the minimum sort rather than the maximum sort.
I would really like to work out a irrelevance inference, any help is appreciated.
Regarding the Set\omega: It is forbidden in Agda, so some things cannot be expressed. But if we add it to Agda and internally use a Set(\omega + 1) to type Set\omega, would there not again things you cannot express?
Of course, there is no reason why the hierarchy should stop at \omega, you could go to higher ordinals... :-) However, maybe we should wait with this until practical applications appear that use more than 3 levels. :-)
Cheers,
Andreas
On Sep 14, 2010, at 8:07 PM, Dan Doel wrote:
On Tuesday 14 September 2010 8:56:30 am Andreas Abel wrote:
This ensures that levels remain irrelevant for
computation, they are only there to sort out the universe
stratification.  This is in analogy to sizes in the type-based
termination approach: sizes are only there to sort out the
termination, they are computationally irrelevant.
Ah. I guess this solves the gotchas I'd thought of in this regard. I knew that
people weren't happy with Agda's having non-parametric quantification over
levels for use in Sets. However, I had thought that even without case
analysis, you could do the following:
 embed : Nat -> Level
 embed zero    = zero
 embed (suc n) = suc (embed n)
 f : (n : Nat) -> ... embed n ...
and regain non-parametric quantification (by analysis on Nat), even without
eliminators for Level. But, if Level is always irrelevent, embed is not a
valid function (if this is anything like erasure pure type systems *).
My own thoughts on the issue were a bit wackier. I've been interested in
EPTSes for a while, and came up with a way (I think), to extend them to
provide some solutions. The EPTSes in the linked paper are presented as having
function space rules like ordinary pure type systems. But, what if we allowed
them to know whether irrelevant or relevant quantification is being performed,
too (and for universe polymorphism, tell it what variable is being bound)?
Then rules are of the form (sticking to functional relations):
(var, phase, sort, sort) -> sort
(that may not be an ideal presentation of the rules, but it should suffice)
The ordinary part of the hierarchy would go:
 (v, _, Set i, Set j) -> Set (lub i j) if v is not free in j
And for universe polymorphism, we can add:
 (v, c, Set i, Set j) -> Setω if v is free in j
The important part being that this only allows computationally irrelevant
function spaces to be used for universe polymorphism. This means that embed is
now valid:
 Nat : Set 0, Level : Set 0
 rule (_, r, Set 0, Set 0) = Set 0
But, when we go to try and use it to enable non-parametric universe
dependence, we fail:
 f : (n : Nat) -> ... T : Set (embed n) ...
 f zero    = ...
 f (suc n) = ...
 Nat : Set 0, T : Set (embed n)
 rule (n, r, Set 0, Set (embed n)) = error
So, appropriate behavior is not ensured by making Level itself inherently
irrelevant, but by ensuring that only irrelevant things (regardless of type)
are used in universe polymorphism. For instance, we could instead write
(using, I think, similar notation to the irrelevance stuff you've proposed for
Agda):
 g : .(n : Nat) -> ... T : Set (embed n) ...
 g n {- no case analysis -} = ...
(I also have another idea of where the above style rules could be useful. **)
Note that Setω is not part of the Agda syntax, it is used
only internally, and plays the role of "Type" in the Martin-L"of
logical framework.
I know. Although, I think it could be useful (and non-problematic) to allow
talking about it. I have my own simple interpreter for fooling with Agda-like
universe stuff (without the irrelevance stuff I mentioned above; I haven't
gotten around to implementing something with all that yet), and it allows
sigma types like:
 (Σ i : Level. Σ T : Set i. T) : Ω
(incidentally, I also think a type not of the form SetN is kind of appropriate
as a top, because Setω kind of makes ω look like a Level.) But you cannot
construct a similar type in Agda:
 data All : Setω where
   con : (i : Level) -> (T : Set i) -> T -> All
because that "Setω" is an error. Yet for any All -> T, the corresponding
curried function is allowed.
I think we have a systematic and fairly simple solution to the problem
of universe polymorphism.
I do like it. Making universe levels (roughly) ordinary, first-class values
seems simpler and more natural than a lot of other proposals I've seen. But I
can understand people being a weirded out by, essentially, Set being a family
that contains its own index/parameter type.
-- Dan
[*] http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.156.2558
[**] One redundancy of EPTSes is that quantification on Sets is probably
naturally parametric when doing (x : Set i) -> (T : Set j) i > j stuff. It is
in Agda, I believe. You could solve this redundancy by adding type case as a
language primitive. Then parametric quantification would ensure that type case
isn't used, and types could be erased.
But, you could also use the above rules to disallow using the ordinary
function space where it's necessarily parametric, like so (ignoring variables
for now):
And now we can no longer write:
 id : (A : Set) -> A -> A
only:
 id : .(A : Set) -> A -> A
Forcing us to tag all the Sets that can be erased. I'm not actually certain
this is useful, since it imposes an additional burden on the programmer to
provide information the compiler could figure out, but it might be interesting
in an intermediate language.
Andreas Abel  <><      Du bist der geliebte Mensch.
Theoretical Computer Science, University of Munich
Oettingenstr. 67, D-80538 Munich, GERMANY
andreas.abel AT ifi.lmu.de
http://www2.tcs.ifi.lmu.de/~abel/
