- To: coq-club AT inria.fr
- Subject: [Coq-Club] Testing monads in Alea library
- Date: Fri, 20 May 2011 17:24:00 +0200
Hello,
Is there a way to test (complex) functions based on monads used in the alea library for randomized algorithm ? I want to know if the functions I make really corresponds to what I expect them to do before starting to analyze them.
For example, I want to produce a list of bits generated by a coin flip. I want to stop it as soon as true is flipped. I made this function below :
Add LoadPath "../alea-v5".
Require Export Prog.
Require Import List.
Instance Test_mon :
monotonic (fun (f: (list nat) -> distr (list nat)) (x: (list nat)) =>
(Mif Flip (f (1%nat::x)) (Munit (0%nat::x)))).
red;intros;intro p;apply Mif_le_compat;auto.
Qed.
Definition Test : ((list nat) -> distr (list nat)) -m> ((list nat) -> distr (list nat)) :=
mon (fun (f: (list nat) -> distr (list nat)) (x: (list nat)) =>
(Mif Flip (f (1%nat:: x)) (Munit (0%nat::x)))).
This function stops when a false is flipped (and not true as I wanted). Is there a means to detect this error ? Are some possible outputs be computed ?
Thanks in advance,
Allyx
- [Coq-Club] Testing monads in Alea library, Allyx FONTAINE
- <Possible follow-ups>
- Re: [Coq-Club] Testing monads in Alea library,
Pierre Corbineau
Allyx FONTAINE
AUGER Cedric
Allyx FONTAINE
David Baelde
- Re: [Coq-Club] Testing monads in Alea library, AUGER Cedric
- Re: [Coq-Club] Testing monads in Alea library, Fontaine Allyx
David Baelde
Allyx FONTAINE
AUGER Cedric
Allyx FONTAINE
Pierre Corbineau
