- From: Pierre Corbineau <Pierre.Corbineau AT imag.fr>
- To: Allyx FONTAINE <fontaine AT labri.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Testing monads in Alea library
- Date: Fri, 20 May 2011 17:48:29 +0200
- Mailscanner-null-check: 1306511307.76029@OlXBEMPcktPWzRs2y3PVAg
- Organization: Verimag
Dear Allyx,
Within Coq, all you can do with Alea distrs is evaluate the probability of a certain (computable) event to happen by using the mu function (which is actually a projection). This probably isn't what you want.
I think you might try to extract Alea Functions to a randomized Ocaml program using the following translation:
Distr A => 'a distr == unit -> 'a (random function)
let draw d = d ();;
Flip => (Random.bool: bool distr)
Munit => fun x => fun () => x :'a -> 'a distr
Mlet => fun d f => f (draw d) : 'a distr -> (a' -> 'b distr) -> 'b distr
Maybe another Pierre can help you there...
Pierre Corbineau
Le 20/05/2011 17:24, Allyx FONTAINE a écrit :
Hello,
Is there a way to test (complex) functions based on monads used in the
alea library for randomized algorithm ? I want to know if the functions
I make really corresponds to what I expect them to do before starting to
analyze them.
For example, I want to produce a list of bits generated by a coin flip.
I want to stop it as soon as true is flipped. I made this function below :
Add LoadPath "../alea-v5".
Require Export Prog.
Require Import List.
Instance Test_mon :
monotonic (fun (f: (list nat) -> distr (list nat)) (x: (list nat)) =>
(Mif Flip (f (1%nat::x)) (Munit (0%nat::x)))).
red;intros;intro p;apply Mif_le_compat;auto.
Qed.
Definition Test : ((list nat) -> distr (list nat)) -m> ((list nat) ->
distr (list nat)) :=
mon (fun (f: (list nat) -> distr (list nat)) (x: (list nat)) =>
(Mif Flip (f (1%nat:: x)) (Munit (0%nat::x)))).
This function stops when a false is flipped (and not true as I wanted).
Is there a means to detect this error ? Are some possible outputs be
computed ?
Thanks in advance,
Allyx
Pierre Corbineau |
VERIMAG - Centre Équation | Tel: (+33 / 0) 4 56 52 04 42
2, avenue de Vignate | Office nr B18
38610 GIÈRES - FRANCE | http://www-verimag.imag.fr/~corbinea/
begin:vcard fn:Pierre Corbineau n:Corbineau;Pierre org;quoted-printable:Universit=C3=A9 Joseph Fourier - Grenoble 1;Laboratoire VERIMAG - Polytech' Grenoble adr;quoted-printable;quoted-printable:2, avenue de Vignate;;VERIMAG - Centre =C3=89QUATION ;GI=C3=88RES ;;38610;France email;internet:Pierre.Corbineau AT imag.fr title;quoted-printable:Ma=C3=AEtre de Conf=C3=A9rences tel;work:+33 (0) 4 56 52 04 42 tel;fax:+33 (0) 4 56 52 03 44 x-mozilla-html:FALSE url:http://www-verimag.imag.fr/~corbinea version:2.1 end:vcard
- [Coq-Club] Testing monads in Alea library, Allyx FONTAINE
- <Possible follow-ups>
Allyx FONTAINE
- Re: [Coq-Club] Testing monads in Alea library, Pierre Corbineau
Allyx FONTAINE
AUGER Cedric
Allyx FONTAINE
David Baelde
- Re: [Coq-Club] Testing monads in Alea library, AUGER Cedric
- Re: [Coq-Club] Testing monads in Alea library, Fontaine Allyx
David Baelde
Allyx FONTAINE
AUGER Cedric
Allyx FONTAINE
