coq-club - Re: [Coq-Club] Testing monads in Alea library
chronological Thread
  • To: AUGER Cedric <Cedric.Auger AT lri.fr>
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Testing monads in Alea library
  • Date: Tue, 24 May 2011 15:43:47 +0200
  • Organization: LaBRI - Université Bordeaux 1 - France
Le 24/05/2011 13:15, AUGER Cedric a écrit :
Le Tue, 24 May 2011 10:50:44 +0200,
Fontaine
Allyx<fontaine AT labri.fr>
  a écrit :
Le 23/05/2011 11:18, AUGER Cedric a écrit :
Le Sun, 22 May 2011 17:41:50 +0200,
David
Baelde<david.baelde AT gmail.com>
   a écrit :
Hi Allyx,
If you haven't already, you should have a look at the paper by
Audebaud&   Paulin (http://dx.doi.org/10.1016/j.scico.2007.09.002)
about the ALEA library. It starts with a gentle introduction to the
monad that is used, detailing its advantages and drawbacks.
Long story short, Pierre Corbineau's solution will work. However, I
wouldn't bother to make extraction work for such small examples:
just rewrite the code in ML yourself.
Have fun,
I also guess that if "'a" is a type which cardinality is quite
small, and you can extract [0,1] to float, then you can write a
short ML code:
let dice_throw =
    let sieve = Random.float 1. in
    let rec get_rand acc l =
      match l with
      | v::l ->   let acc = acc + μ v in
                if acc>   sieve then v else get_rand acc l
      | [] ->   failwith "Hmm, this is unexpected!"
    in get_rand 0 [list of all the elements of your type]
of course if you have big types for 'a such as int it can be too
long and even false due to rounding errors (the failwith case can
even occur).
You also have to identify the "μ" function (if it is the one I think
of, it is also called μ in Alea, so it should be extracted to its
Unicode code, as unicode is not supported by OCaml, leading to some
awfull identifier).
Even in this case, I am not sure it can be very usefull, but if it
is, then you won't have to rewrite all the ML code, and won't have
to play with the Extraction mechanism too much (and using P.
Corbineau solution seems also hazardous, as you change the
extracted objects to objects which are semantically very different;
furthermore, using side effects can mess a lot with extraction if
some optimizations are performed ("let x = side_effect () in let y
= side_effect () in ..." could be extracted to "let x = side_effect
() in let y = x in ..." as well as identity due to Coq semantics,
but the two functions are clearly different with OCaml)).
Thanks for your answers!
Actually, as I have several examples more or less simple, I would
like to have an automatic way which ensures that Ocaml functions
really corresponds to Coq functions. But as I don't know well all
those mechanisms, I indeed begin with writting ML code by myself and
having a look at extraction.
I am not sure of my understanding of the role of the accumulator in
dice_throw. Is it needed to return an element of my type uniformly at
random thanks to the μ function? Does the failwith case not be
reached because the sum of the probabilities is supposed to be
greater than 1?
Allyx
Almost yes for the last paragraph (in fact the sum is expected to be
exactly 1, and not "greater" than 1; in french "greater" has a large
meaning, but in english it has a strict one).
In fact I never used the Alea library, so what I wrote may be wrong,
but if you want some commented version of the function I wrote:
(with the notation:
Int(a,b,P) for:
  b
∫ P(x) ∂x
  a
and:
f^(-1) for:
f⁻¹
  let dice_throw =
     (*First we throw a dice on [0,1] with uniform probability,
       assuming [Random.float] is able to do so,
       which is not the case in fact as it is a pseudo-random
       generator and float doesn't cover all reals in [0,1],
       but it is expected to be a good approximation of this law.
       Let us bind this result to the "sieve" identifier.
     (* Now thanks to theorems which I do not remember the names,
        we have some transfer function between uniform law and
        any Riemann integrable law P on [a, b] such that Int(a,b,P)=1
        (I don't recall if it can be generalized to Lebesgue,
         but that doesn't matter here) with:
         X |-->  (x |-->  Int(a, x, P))^(-1)(X)
        So that now we want to compute "(x |-->  Int(a, x, P))^(-1)"
       (* [acc] is meant to be "Int(a, predecessor(List.hd l), P)"
          where [a] is the first element of the type
          (in fact as the type is finite, the integral is just
           a finite sum)
       match l with
       | v::l ->   let acc = acc + μ v in (*μ is our P law*)
                 if acc>   sieve
                 then v (*ok, we have reversed our integral*)
                 else get_rand acc l
                  (*we didn't reverse our integral and had to go
                    further*)
       | [] ->  (*if this point is reached, then by definition
                 of probability laws, we should have that [acc]=1.
                 and so, due to definition of sieve we should have
                 halted earlier. Of course due to rounding,
                 we could have [acc]=0.99988665 or so and
                 [sieve] = 0.9999039 or so, so that this case
                 may happen if we are very unlucky
    in
Hope these comments are not too messy!
Once again, I guess it is what you would like, but I am not sure it is
very convenient. And if you want to do big benchmarks to be able to
make some observations, it may be quite slow. But I have no really
better solution.
Thanks a lot for the explanations! It's much more clear for me now.
Allyx
