coq-club - Re: [Coq-Club] Testing monads in Alea library
chronological Thread
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Testing monads in Alea library
  • Date: Tue, 24 May 2011 10:50:44 +0200
  • Organization: LaBRI - Université Bordeaux 1 - France
Le 23/05/2011 11:18, AUGER Cedric a écrit :
Le Sun, 22 May 2011 17:41:50 +0200,
David
Baelde<david.baelde AT gmail.com>
  a écrit :
Hi Allyx,
If you haven't already, you should have a look at the paper by
Audebaud&  Paulin (http://dx.doi.org/10.1016/j.scico.2007.09.002)
about the ALEA library. It starts with a gentle introduction to the
monad that is used, detailing its advantages and drawbacks.
There are mainly two ways of representing probabilistic algorithms. A
computation returning objects of type 'a can be represented either as
(unit ->  'a) or ('a ->  [0,1]). The first approach is suitable for
simulations: it gives you a function that you can re-run as many times
as you wish, possibly getting different results each time, because the
function relies on some random generator. The second approach, used in
ALEA, models the computation as a probability distribution. It is an
exact approach: for a given x of type 'a it should return the
probability that this x is obtained. But this will be unusable for
testing.
Long story short, Pierre Corbineau's solution will work. However, I
wouldn't bother to make extraction work for such small examples: just
rewrite the code in ML yourself.
Have fun,
I also guess that if "'a" is a type which cardinality is quite small,
and you can extract [0,1] to float, then you can write a short ML code:
let dice_throw =
   let sieve = Random.float 1. in
   let rec get_rand acc l =
     match l with
     | v::l ->  let acc = acc + μ v in
               if acc>  sieve then v else get_rand acc l
     | [] ->  failwith "Hmm, this is unexpected!"
   in get_rand 0 [list of all the elements of your type]
of course if you have big types for 'a such as int it can be too long
and even false due to rounding errors (the failwith case can even
occur).
You also have to identify the "μ" function (if it is the one I think
of, it is also called μ in Alea, so it should be extracted to its
Unicode code, as unicode is not supported by OCaml, leading to some
awfull identifier).
Even in this case, I am not sure it can be very usefull, but if it is,
then you won't have to rewrite all the ML code, and won't have to play
with the Extraction mechanism too much (and using P. Corbineau
solution seems also hazardous, as you change the extracted objects to
objects which are semantically very different; furthermore, using
side effects can mess a lot with extraction if some optimizations are
performed ("let x = side_effect () in let y = side_effect () in ..."
could be extracted to "let x = side_effect () in let y = x in ..." as
well as identity due to Coq semantics, but the two functions are
clearly different with OCaml)).
Thanks for your answers!
Actually, as I have several examples more or less simple, I would like to have an automatic way which ensures that Ocaml functions really corresponds to Coq functions. But as I don't know well all those mechanisms, I indeed begin with writting ML code by myself and having a look at extraction.
I am not sure of my understanding of the role of the accumulator in dice_throw. Is it needed to return an element of my type uniformly at random thanks to the μ function? Does the failwith case not be reached because the sum of the probabilities is supposed to be greater than 1?
Allyx
