- To: Pierre Corbineau <Pierre.Corbineau AT imag.fr>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Testing monads in Alea library
- Date: Fri, 20 May 2011 19:20:56 +0200
Thank you Pierre for your answer.
That's exactly it. Before launching into probability evaluations, I would like to test my functions.
You speak about translations. Does that mean that, instead of using the Coq extraction command, I'll have to translate my Coq function using the existant randomized Ocaml functions (I am not really familiar with code extraction)?
Allyx
Le 20/05/2011 17:48, Pierre Corbineau a écrit :
Dear Allyx,
Within Coq, all you can do with Alea distrs is evaluate the probability of a certain (computable) event to happen by using the mu function (which is actually a projection). This probably isn't what you want.
I think you might try to extract Alea Functions to a randomized Ocaml program using the following translation:
Distr A => 'a distr == unit -> 'a (random function)
let draw d = d ();;
Flip => (Random.bool: bool distr)
Munit => fun x => fun () => x :'a -> 'a distr
Mlet => fun d f => f (draw d) : 'a distr -> (a' -> 'b distr) -> 'b distr
Maybe another Pierre can help you there...
Pierre Corbineau
Le 20/05/2011 17:24, Allyx FONTAINE a écrit :
Hello,
Is there a way to test (complex) functions based on monads used in the
alea library for randomized algorithm ? I want to know if the functions
I make really corresponds to what I expect them to do before starting to
analyze them.
For example, I want to produce a list of bits generated by a coin flip.
I want to stop it as soon as true is flipped. I made this function below :
Add LoadPath "../alea-v5".
Require Export Prog.
Require Import List.
Instance Test_mon :
monotonic (fun (f: (list nat) -> distr (list nat)) (x: (list nat)) =>
(Mif Flip (f (1%nat::x)) (Munit (0%nat::x)))).
red;intros;intro p;apply Mif_le_compat;auto.
Qed.
Definition Test : ((list nat) -> distr (list nat)) -m> ((list nat) ->
distr (list nat)) :=
mon (fun (f: (list nat) -> distr (list nat)) (x: (list nat)) =>
(Mif Flip (f (1%nat:: x)) (Munit (0%nat::x)))).
This function stops when a false is flipped (and not true as I wanted).
Is there a means to detect this error ? Are some possible outputs be
computed ?
Thanks in advance,
Allyx
- [Coq-Club] Testing monads in Alea library, Allyx FONTAINE
- <Possible follow-ups>
Allyx FONTAINE
- Re: [Coq-Club] Testing monads in Alea library,
Pierre Corbineau
- Re: [Coq-Club] Testing monads in Alea library, Allyx FONTAINE
AUGER Cedric
Allyx FONTAINE
David Baelde
- Re: [Coq-Club] Testing monads in Alea library, AUGER Cedric
- Re: [Coq-Club] Testing monads in Alea library, Fontaine Allyx
David Baelde
Allyx FONTAINE
AUGER Cedric
Pierre Corbineau
