coq-club - Re: [Coq-Club] Testing monads in Alea library
chronological Thread
  • To: AUGER Cedric <Cedric.Auger AT lri.fr>
  • Cc: Pierre Corbineau <Pierre.Corbineau AT imag.fr>, coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Testing monads in Alea library
  • Date: Sat, 21 May 2011 15:17:49 +0200
Thanks a lot ! So I'll have a look at all those functionnalities.
Allyx
Le 20/05/2011 19:30, AUGER Cedric a écrit :
Le Fri, 20 May 2011 19:20:56 +0200,
Allyx
FONTAINE<fontaine AT labri.fr>
  a écrit :
Thank you Pierre for your answer.
That's exactly it. Before launching into probability evaluations, I
would like to test my functions.
You speak about translations. Does that mean that, instead of using
the Coq extraction command, I'll have to translate my Coq function
using the existant randomized Ocaml functions  (I am not really
familiar with code extraction)?
I wrote some tutorial on extraction here[1] (but I guess it is not a
good one to start)
What Pierre mean, AFAIU, is that you may want to have some extraction
of axiom to do what you want.
Record distr (A:Type) : Type :=
   {μ : M A;
    mu_stable_inv : stable_inv μ;
    mu_stable_plus : stable_plus μ;
    mu_stable_mult : stable_mult μ;
    mu_continuous : continuous μ}.
Definition Flip : distr bool.
is not good for you to test, as it won't provide dices throws.
If you want to test with some Monte-Carlo methods or so, you will need
to have a dice trower, and tell coq to use it instead of your "distr"
which only computes probabilities.
For that you can try:
Extract Constant distr =>  "unit ->  'a".
Extract Inductive bool =>  "bool" ["true" "false"].
Extract Constant Flip =>  "Random.bool".
And so on, but if you are not familiar to extraction I would not advise
you to do so; maybe have a try on simpler libraries for extraction
before venturing forth.
So for an answer, you only have to use extraction, but you need to take
a look at all the functionnalities of the extraction mechanism (and
know of the OCaml functions and types to inform the extractor).
[1] http://coq.inria.fr/cocorico/AUGER_ExtractionTuto
Allyx
Le 20/05/2011 17:48, Pierre Corbineau a écrit :
Dear Allyx,
Within Coq, all you can do with Alea distrs is evaluate the
probability of a certain (computable) event to happen by using the
mu function (which is actually a projection). This probably isn't
what you want.
I think you might try to extract Alea Functions to a randomized
Ocaml program using the following translation:
Distr A =>  'a distr == unit ->  'a (random function)
let draw d = d ();;
Flip =>  (Random.bool: bool distr)
Munit =>  fun x =>  fun () =>  x :'a ->  'a distr
Mlet =>  fun d f =>  f (draw d) : 'a distr ->  (a' ->  'b distr) ->  'b
distr
Maybe another Pierre can help you there...
Pierre Corbineau
Le 20/05/2011 17:24, Allyx FONTAINE a écrit :
Hello,
Is there a way to test (complex) functions based on monads used in
the alea library for randomized algorithm ? I want to know if the
functions I make really corresponds to what I expect them to do
before starting to analyze them.
For example, I want to produce a list of bits generated by a coin
flip. I want to stop it as soon as true is flipped. I made this
function below :
Add LoadPath "../alea-v5".
Require Export Prog.
Require Import List.
Instance Test_mon :
monotonic (fun (f: (list nat) ->  distr (list nat)) (x: (list nat))
=>  (Mif Flip (f (1%nat::x)) (Munit (0%nat::x)))).
red;intros;intro p;apply Mif_le_compat;auto.
Qed.
Definition Test : ((list nat) ->  distr (list nat)) -m>  ((list nat)
->  distr (list nat)) :=
mon (fun (f: (list nat) ->  distr (list nat)) (x: (list nat)) =>
(Mif Flip (f (1%nat:: x)) (Munit (0%nat::x)))).
This function stops when a false is flipped (and not true as I
wanted). Is there a means to detect this error ? Are some possible
outputs be computed ?
Thanks in advance,
Allyx
