- To: Carlos Simpson <Carlos.Simpson AT unice.fr>
- Cc: Andrew Cave <acave1 AT cs.mcgill.ca>, Victor Porton <porton AT narod.ru>, Thorsten Altenkirch <txa AT Cs.Nott.AC.UK>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] quotients
- Date: Thu, 10 Nov 2011 11:47:12 -0500 (EST)
On Wed, 9 Nov 2011, Carlos Simpson wrote:
Dear Russell,
Thanks, that's illuminating. I guess the question which can make us
uneasy about using setoids, is whether it causes too much extra effort to
prove that all functions are compatible all the time? That kind of fear does
sometimes prove to be overblown.
The amount of work needed to prove that functions are respectful is exactly the amount of work needed to show that a function is well-defined using quotients (ie the work needed to satisfy the hypothesis of ZornsLemma.Quotients.induced_fuction). Then some sort of type-class mechanism needs to take over to prove that compositions of respectful functions are respectful.
One imagines that all of the CIC operations we can do on types, need to be done by hand for setoids. Is it the case that you actually end up having only a small number of these to do in practice? ---Carlos
There is something to this point. You need need to write a library to make products of setoid, and disjoint unions of setoids, and setoid function spaces (*). However, I never really had a problem with this because we have to do this sort of thing all the time anyways. So, for example, when doing my work on metric spaces I needed to define a metric for the product of two metric spaces, and a metric for functions between metric spaces, etc. Since I had to all this work anyways, I didn't find it particularly burdensome to define these operations on setoids while I was at it.
(*) Actually I did discover some annoyance with setoids and function spaces. You need to put a setoid structure on a sigma-type of functions that are respectful. What I discovered was that everything would probably be better if PERs were used instead of setoids. The PER of functions between Setoids is exactly what you expect:
f ~~ g := forall x y, x == y -> f x == g y
And we immediately get that a function f is respectful when f ~~ f. And this definition extends to the PER of functions between PERs
f ~~ g := forall x y, x ~~ y -> f x ~~ g y
I spent a while slogging through this PER stuff and every obstacle I encountered eventually yielded to an elegant solution. I suspect that the experts on PERs already knew all this stuff I was discovering. Unfortunately at the time (several years ago) I couldn't quite get the support out of Mathieu's type class mechanism that I needed to make this seamless. I suspect it would be easier today or one could use Canonical Structures instead. I would encourage the development and use of PERs instead of setoids.
Russell O'Connor <http://r6.ca/>
``All talk about `theft,''' the general counsel of the American Graphophone
Company wrote, ``is the merest claptrap, for there exists no property in
ideas musical, literary or artistic, except as defined by statute.''
- Re: [Coq-Club] I'm against setoids and pro ZF, (continued)
- Message not available
- Re: [Coq-Club] I'm against setoids and pro ZF, Bruno Barras
Matthieu Sozeau
- Re: [Coq-Club] I'm against setoids and pro ZF, Thorsten Altenkirch
roconnor
- Re: [Coq-Club] quotients,
Carlos Simpson
- Re: [Coq-Club] quotients, Andrew Cave
roconnor
Carlos Simpson
roconnor
Carlos Simpson
- Re: [Coq-Club] quotients, roconnor
- Re: [Coq-Club] quotients, Bas Spitters
- Re: [Coq-Club] quotients, Andrej Bauer
- Re: [Coq-Club] quotients, Peter Vincent Homeier
Carlos Simpson
roconnor
Carlos Simpson
- Re: [Coq-Club] quotients, Daniel Schepler
Carlos Simpson
- Re: [Coq-Club] I'm against setoids and pro ZF, Michael Shulman
